Outdrive/redline oil >
Old 02-17-2003 | 07:53 PM
CAP071's Avatar
Question Outdrive/redline oil
I was going to run redline synthetic lube in my outdrive this year. I see they sell redline shock Heavy, medium and light? what 1 should I run?
CAP071 is offline
Old 02-18-2003 | 03:03 PM
bobby daniels
In your boat unless its blown run the med. or light .!!!!I use the heavy only in heavy ,high H.P. boats But either of the above will work fine ,,, -I've used it for years
Old 02-18-2003 | 03:49 PM
Wally's Avatar
Were doomed!
Call Red Line directly and ask the tech guys..they will tell you what you should run in your app. They told me to run the Shock proof heavy in my Scarab with TRS drives.
-Wally
Wally is offline
Old 02-18-2003 | 04:13 PM
Donzi38ZX's Avatar
I have only seen Heavy, light and superlight. Would your Medium recomendation be the light? I'm not really trying to be a smarta$$, comes naturally , but I would like to know as I am thinking of running shockproof in my Bravo XZs behind HP500EFIs. Also would you always recomend shockproof in marine outdrives?
Donzi38ZX is offline
Old 02-18-2003 | 04:21 PM
Donzi38ZX's Avatar
I called redline they told me shockproof heavy for virtually all I/O applications due to excessive load. He even said to use heavy behind a V6. Recommended light in a superlight outboard setup. Didn't sound like they typically recommended superlight for marine application. Now where do I buy it?
Old 02-18-2003 | 05:24 PM
bobby daniels
Yep they really like the heavy and we tried the different weights and the heavy does so less wear in 1 season in heavy boats or boats with alot of h.p.!!
never use super lite ------
summit has it or 803-329-8658 can ship it to you with your app.I'd stay with the heavy ,and do what they say ,they sure know better than me
any of it is killer stuff !!!!!!!!!!!
Old 02-18-2003 | 05:50 PM
Dang, I will add that to my order, I am bangin out a list for Summit right now that would finance a small country!
BadDog is offline
Old 02-18-2003 | 06:06 PM
CAP071's Avatar
I found a whole page of redline oils at WWW.FISHERMOTORSPORTS.COM
they sell it by the gallons or by quart. I wanna see who has it cheapest?
CAP071 is offline
Old 02-18-2003 | 06:09 PM
CAP071's Avatar
OPPS make that WWW.FISHERMOTORSPORT.COM
NOT SPORTS I found it under the lubrication link on the home page
CAP071 is offline
Old 02-18-2003 | 06:19 PM
CAP071's Avatar
I just checked both are $7.95 a quart.
CAP071 is offline
