How many GPM does a Bravo water pump flow?
Yes I know there are a lot of variables but approximately how many GPM would a Bravo water pump flow out the exhaust at various RPM? Needing this info to size some bypass and check valves. New design in the works. Just ballpark figures at this point, the valves will have a range to work within.
Tim T.
Tim T.
Official OSO boat whore
I researched this extensivly some time ago. The result? Nobody really knows. The best that I could come up with was around 30gpm at full song. Honestly, that was based off of some loose calculations and is really a wild ass guess.
It depends on RPM, speed, and inlet type. Remember it is a floppy vane so the more inlet pressure supporting the back of the vanes, the more output flow potential before the vanes bend and "cavitate". It could be more than 40 GPM depending on those variables.
I too , did some research last year. The results...Jabscos "Merc replacement " pump is 22 gpm at 2000 rpm. Beyond 2000 the impeller pretty much acts like a blender and just mixes stuff up and the water is forced though by your forward speed.
I don't Imagine the Merc is much different
unless you are going to design something into the system using thermodynamics, flows, heat transfer, energy, chemical equilibrium...yada,yada, yada...mopower looks like he has some data for ya.
heat transfer, and GPM is not our issue....actually most of the time we have too much,,,,which translates into wasted HP...just a little tip.....ANY more flow or pressure than you need is wasted,,,,well at least in our eyes
..... energy can not be created or destroyed...but what do i know?
Yes, that is a given. We are shooting for flow in a system that will have no more than 25 to 30 psi block pressure at WOT. This would requrie the given restriction to not be to small and create excess pressure. If the restriction were large PSI would be low and flow high and vice versa. The question then becomes (with exhast header being the restriction) how many gallons will you flow at 25 psi?
