502 mpi adjustable fuel pressure regulator
502 mpi adjustable fuel pressure regulator (Post #1)
Does any one have excpience with this, how hard is the install? Can anyone explain it? I've installed headers and flame arrestor and I think I can avoid having my ecu done by doing this
Not sure if your going to need it,,, I put Gil magnum choice headers and a K and N flame arrestor on and it put the motor right where it needed to be,,,, run it for a blast and take a look at the plugs,,, you might not need to do anything.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I installed one on mine. It is very difiicult to get too, but what isn't on a boat. The regulator in under the exhaust manifold on the port side of the engine. It is enclosed in a box that you will have to modify for it to fit in. Once you get the regulator off it is a piece of cake from there on out until it is time to re-install it. I also added a fuel pressure gauge to be able to set it by, and keep an eye on it just in case the jamb nut came loose and it moved. The reason I added mine was because all I did at one time I thought I might need it. I have the Lightning Headers, Re-programmed ECU, Vortech flame arrestor, and MSD box. All of which make the engine run leaner. Hope this helps.
I'm pretty sure mine is set at 42 psi. I will check this weekend, I'm finishing up with my sea strainer. I will need to start it and check for leaks. I will let you know if it is anything different.
