Subwoofer Location on 28' ?? >
Old 02-27-2003 | 08:24 AM
Pantera24's Avatar
Default Subwoofer Location on 28' ??
Ok. Looking for the best place to put a subwoofer in the 28'?
Pics would be helpful.
Angel
Pantera24 is offline
Old 02-27-2003 | 10:21 AM
Thirsty Turtle's Avatar
I'm looking for that too. I found a pre-made sealed box that will fit under the seat with a 10" sub facing up. Also wondered about putting it in the cabin....in the compartment that looks like where a porti-potti would go.
An 8" Bazooka Bass Tube would fit under the seat also without losing alot of room.
Bruce
Thirsty Turtle is offline
Old 02-27-2003 | 11:08 AM
Pantera24's Avatar
Yea ... I'm leaning towards having it placed in the cabin somewhere. Just not sure where yet.
Angel
Old 03-02-2003 | 06:14 PM
I had a car stereo guy build the box to fit between the middle rear seat posts. It will hold two 10in woofers. He waterproofed the box with resin and put carpet around it. I have the speakers facing toward the back. Sounds great.
Denny is offline
Old 03-02-2003 | 09:21 PM
Pantera24's Avatar
Denny,
Sounds interesting..do you have any pics.??
Angel
Old 03-04-2003 | 06:48 PM
Angel, Sorry I do not have any pictures. All you see is the grey carpet on the back of the box. It blends with the floor. It fits perfect and does not extend beyond the seat. In fact it sit two to three inches behind the front of the rear seat. I have seen another Pantera where the subs were cut out in the left and right sides under the seats. You have all the space under the rear seat that way.
Denny is offline
Old 03-04-2003 | 09:20 PM
Tim G.'s Avatar
Performance Boat Center
Mine are under the rear seat, cut into the gunnels on either side. Sounds pretty good, but I'd go with the Box like Denny is talking about if you think you really need more bass reverb.
Tunes? My twin 502 Mags make the real music...
When's that boat going in the water Angel??? You know I'm ready when you are.
Ran the boat around Biscayne Bay last Friday afternoon/evening. Water was a perfect 1-2 chop. We ran an easy 70, with the trim in and dragging a little tab. It was like riding on glass. I had a lot more to go, but the girlfriend was getting a little upset, to say the least.. 4000 rpm is the real music.. I was aiming for 5k, but the screams were holding me back..
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 03-04-2003 | 09:59 PM
Pantera24's Avatar
Tim,
Glad to hear your up and running again.!!!
Yea I'll probably go with the subs under the rear bench.
True ...there is no better music than the lumpty..lump during idle.
BUT I also like hearing some tunes when anchored or cruising.
Pepe says it should be about 2 more weeks and we should be ready.
Sounds like you gave your girlfriend a good scare..hehehe
I'll let you know as soon as I'm ready to make a day of it in the bay.
Angel
Old 03-05-2003 | 11:15 PM
Thumbs up
Decided to build a box like Denny's and put the sub under the seat. Bought a 10" sub that needs a ported box of 0.9 cu.ft.
It's a wedge shaped box using 5/8" High Density Particle Board.
Here's the outside dimensions:
Height= 11.5
Width= 15
Top Depth= 12.5
Bottom Depth=15
Actual volume is 1.1 cu. ft. but when you take into account some bracing and the cone volume it works out to the 0.9.
It will fire towards the rear. It'll be resin coated and either painted or carpeted.
Does paint stick to the resin?? Maybe just a good polyurethane paint?
I'll let ya'll know how it turns out!
Old 03-06-2003 | 10:10 AM
Caincando1's Avatar
Can't wait to see it TT...and hear it.
What did you get for a Sub?
Caincando1 is offline
