Oil pan drain kit
I'm looking for a way to install a drain hose on a Baja 29' Outlaw with twin engines. Is there some kit that can be purchased to where both hoses can be attached to the oil pan and then tee together to one hose and run to the drain plug?
Any info will be appreciated.
By two kits; and drain them individually. You are going to have level and contamination problems if something ever happens to one engine; like milkshake, spinning a bearing, or the unthinkable. Don't blow two engines.
