Supercharging smallblocks >
Old 03-10-2003 | 05:07 PM
Default Supercharging smallblocks
This is a thread that got deleated CHIT!!!!!!!....guess we had to take one for the team..... Anyway the thread involved Dustin Whipple and he was telling us about the various smallblock applications he has done. My last post asked what carb he used and is it included in the kit? Also, is the kit intended for a bone stock marine 350 or is there any other reccomended upgrades like perhaps a larger oil pan or oil cooler or an ignition upgrade etc etc. Also, do you reccomend the engines to be totally fresh or is it ok to have a few hours on them, a compression/leakdown test??.........doug
pullmytrigger is offline
Old 03-10-2003 | 11:22 PM
Whipple Charged's Avatar
Doug, we don't include carbs with our kits, on bone stock, a Holley 650 is fine. The same system will fit almost all variances so it's up to you what changes you want to make. Aluminum heads are a great choice, but the SC is the single most important ingrediant and will grow with your changes so I think that should be the first thing and upgrade as time goes on.
Oil coolers are always recommended as well as a nice big pan. I use Olson oil pans for almost every project. Ignition, not at first, but later as you want increase power, you'll need to upgrade. The SC system is very modular.
Thanks,
Dustin
Whipple Charged is offline
Old 03-11-2003 | 06:47 AM
do guys use the stock exhaust manifolds???
Old 03-11-2003 | 07:04 AM
Im just trying to get a handle on the extras that pop up on every boat project, its a twin engine boat so they can add up, anything else you like to see?
Old 03-12-2003 | 12:58 AM
depends on what your trying to do. If you want 50% more power install the supercharger, if you want 60%, install with intercooler and 1lb of boost more as well as large capacity oil coolers. If you want more, install aluminum heads such as Dart Pro One or AFR's and run even more boost and larger capacity oil pan. If your not satisfied with that, install exhaust and camshaft/valve train.
You can do it all at one time or step by step, it's up to you and what you want to get out of the engine.
Dustin
Old 03-12-2003 | 05:34 PM
Very good, thanks Dustin.
doug
SUPERBASH
Superboat
51
04-16-2022 06:07 AM
cstobe
11
11-21-2006 02:25 PM
Big Block Billy
24
01-10-2005 10:52 PM
GO4BROKE
01-06-2003 10:18 AM
checkmate981
Sunsation
13
09-17-2002 08:26 PM
