Painting Drives
Old 03-10-2003 | 10:28 PM
RUSSSR1's Avatar
Default Painting Drives
OK the drives are striped but what do I use to fill in the pitts from corrosion sp? What will hold to aluminum and not pop out after I spend all this time making them look good?
RUSSSR1 is offline
Old 03-11-2003 | 06:44 AM
Audiofn's Avatar
Charter Member #232
I would paint them with a really good etching paint. Remember that alluminum corodes in about 30 min there will be a skin of corrosion on it, so you want to prep it and get it to prime ASAP. After that since your pits are probably all fine then take a finish bondo and use that to fair it out. Then sand, prime again because when you sand you will go through the primer in a lot of places then paint with a quality eurathane.
Jon
Put your best foot forward!
Audiofn is offline
Old 03-11-2003 | 06:45 AM
Audiofn's Avatar
Charter Member #232
You picked a bad week to actually want boating info
Jon
Audiofn is offline
Old 03-11-2003 | 06:48 AM
SABER28's Avatar
try all-metal, its a bondo like product that sticks to metal very well
SABER28 is offline
Old 03-11-2003 | 08:42 AM
RUSSSR1's Avatar
Thanks, It looks as if there was no primer under what ever they were done in before. The paint came off in large sheets.
RUSSSR1 is offline
Old 03-11-2003 | 10:13 AM
SummerObsession's Avatar
What about polishing the lowers? Do you lose hydrodynamic efficiency? Other than the maintenance issue, are there advantages or disadvantages?
SummerObsession is offline
nordic95
08-03-2007 03:56 PM
Viaqua
Drives and Lower Units
10
06-16-2007 10:04 PM
jec1521
Detailing, Painting, & Fiberglass
12
07-27-2005 09:10 AM
jec1521
8
07-25-2005 08:21 AM
Bill272
3
05-04-2004 09:37 AM
