Dodge Tomahawk
Old 03-11-2003 | 07:23 AM
Default Dodge Tomahawk
Dodge has a V10 powered motorcycle...the Tomahawk.
4 wheeler goes 300mph, all for $250K!http://www.allpar.com/cars/concepts/tomahawk.html
Back4More is offline
Old 03-11-2003 | 08:06 AM
mcollinstn's Avatar
Styling exercise.
Not capable of turning much better than a dragbike (maximum lean angle of 15 degrees from vertical).
No actual speed calculations were done using hp/resistance, somebody in the development group simply said "holy crap, if the Viper does 185 with this motor, then this thing oughta do 400" and the number stuck.
The motor is required to suck its intake air thru a small snout that snakes thru the bodywork, restricting it from its original 500-horse rating an undetermined amount.
Actual "expected" speed if it still makes 500 horses is in the 260 range (a long way from 400 or 300).
Only holds 2.7 gallons of gas. Just enough to run 5 minutes wide open.
It's very cool, though.
mcollinstn is offline
42FOUNTAIN
5
01-31-2008 07:44 PM
bford1
01-16-2007 05:17 PM
Hardin Marine
New Products and Member Discounts
0
06-15-2006 07:34 PM
GregP
12-31-2004 02:51 PM
dyno
04-12-2003 11:26 AM
