Removing a Bravo 1 outdrive for paint >
Old 03-13-2003 | 06:40 PM
Bajachris
Angry Removing a Bravo 1 outdrive for paint
I would like to remove my Bravo 1 outdrive for painting, what are the steps and any tricks of the trade for removing and reinstalling it later? I plan on painting it ( again). I used the Merc 3 step system before but it mostly pealed off, perhaps a different primer like a zink based. Any good experiences with any systems and or steps for painting aluminum outdrives and K planes. First I have to remove the grass growth from last year.
Thanks for your expert opinions.
Old 03-13-2003 | 06:55 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I have never had any success painting my drives with the Merc spray paint, no matter what type of primer or prep I used. Looks great when finished, but after couple of times to the lake, the paint starts turning whitish and peels off just like your did. Luckly I hit a rock reef and tore my lower up and replaced with new. Not sure I would recommend that route.
Be sure to remove the speedo tube before removing drive. Rest is basic, disconnect trim cyls from drive end, remove 6 nuts, place in reverse,or forward (I forget which) and pull off.
US1 Fountain is offline
Old 03-13-2003 | 07:31 PM
Elite Marine's Avatar
Do a search. There was a really good thread on the proper primer/paint combo that people used successfully.
Elite Marine is offline
Old 03-13-2003 | 07:37 PM
blue thunder's Avatar
If removing and installing the drive by yourself make sure you build a little wooden platform for under the skeg that will support the weight of the drive as you slide it free.
BT
blue thunder is offline
Old 01-18-2004 | 12:13 AM
carter38's Avatar
Try heating up the parts with a heat gun before you put the striper on, went through the same problem the heat works wonders.
carter38 is offline
East Coast B
5
02-11-2007 05:31 PM
fishead
02-24-2005 03:02 PM
GregP
02-19-2004 12:41 PM
olemissalum
5
01-07-2003 06:24 PM
