Maximum Hydraulic Pressures >
Old 03-17-2003 | 11:03 PM
blown formula's Avatar
Question Maximum Hydraulic Pressures
I know we have some experts here so here we go!
What is the maximum pressures developed or used in the three hydraulic system of boats?
Trim (Bravo w/ Prestolite pump)-?
Steering w/Mercruiser Power steering pump w/Latham steering?
K-Planes with Mercruiser tab pump?
I am building some replacement lines & need to know the pressures involved.
Thanks!
blown formula is offline
Old 03-17-2003 | 11:41 PM
rbtnt's Avatar
I think the power steering is 1200 psi.
rbtnt is offline
Old 03-18-2003 | 07:58 AM
Roger 1's Avatar
I think the power steering is 1200 psi. I don`t know why, but for some reason Mercruiser decided to pur 600 psi hose on mine! That lasted for a while but ruptured while I was out on Lake Michigan. I took it off and had a local Hydraulic repair shop make a good one to replace it with.
Roger 1 is offline
Old 03-18-2003 | 08:44 AM
Never really worried about it. -4 and -6 S/S lines are rated at 1500psi or above. Never blew one.
I do know my aftermarket steering rating from the relief valve was 1100 psi.
Gary
Gary Anderson is offline
Old 03-18-2003 | 08:49 AM
Official OSO boat whore
I belive the k-plane and trim system are around 600psi.
Cord is offline
Old 03-18-2003 | 01:57 PM
Thanks Guys, That is about what I thought the pressures were. I just hated to have hoses built & like above, have one burst where it is secured UNDER the engines!. I now feel I can avoid that with certainty.
Old 03-18-2003 | 06:29 PM
doug hess
Trim I/O cylinder and trim tabs are 400 PSI. When replacing the tab hoses last year I could not find any in the 400 to 600 psi range. The rating jumped from 250 to 1200 or 1500.
From Boston Rubber I learned that hose burst pressue is 4 times the working pressure. So the 250 psi hose had an unstated 1000 psi burst pressure. Using 250 psi hose at 400 was at less than 50% burst of burst. With those margins I felt 250 was a safe way to go.
Old 03-18-2003 | 06:52 PM
With the known pressures now, has anyone ever built there own hoses using Earls or JIC type fittings???
Is this practical?
Old 03-18-2003 | 07:57 PM
Mbam's Avatar
Offshoreonly Advertiser
For stock Mercruiswer stuff the steering is 1200 PSI on the high side, 100 PSI on the return. Oildyne pump is set at 2200-2600 PSI high side (up on drive, down on tab- blue wire hot) and 400-600 PSI on the low side. The older Prestolite pump was higher.
The Bennet type tabs have a much lower working pressure, not sure what it is.
I don't like stainless hose for steering as 1 nick in the braid and the pressure capacity is gone, and as far as I know the stainless/teflon hose is the only one with the proper rating, the regular stuff with anodized fittings is not rated that high.
For steering you want a hose with an SAE rating, I can't remember the number but your favorite hose supplier will know, 100R rings a bell.
Mbam is offline
Old 03-18-2003 | 09:33 PM
ALFSTER's Avatar
use any SAE R1 hose its rated at 2200 psi working psi and 8000 burst psi,its also coast gaurd approved for hydraulic use
ALFSTER is offline
