Oil Pump for Gen 6 502 >
Old 03-18-2003 | 03:04 AM
Default Oil Pump for Gen 6 502
Where and what part number for a Gen 6 oil pump? I want to use the same one Mercury uses in the Gen 6 but I am curious if there is a less expensive source for these.
Tim T.
BadDog is offline
Old 06-01-2003 | 08:53 PM
Scott's Avatar
Charter Member #30
TTT
What did you end up with? I think I will be changing mine
I have Steps & Bubbles!
Scott is offline
Old 06-02-2003 | 10:08 AM
Scott's Avatar
Charter Member #30
TTT
I need to know what pump amd pickup combo to order??
Scott is offline
Old 06-02-2003 | 10:41 AM
bobby daniels
I use a moroso pump ,merc uses a mellings hv77 pump the pick up is out of a chevy truck or from merc
The H V stands for high volume and is a fine pump for 28.00 and the moroso is better but 43. dollars
Old 06-02-2003 | 11:06 AM
Scott's Avatar
Charter Member #30
Thanks I wanted to order it today and decided on the MV77HV.
I also decided to use the old pickup since I already have a brace welded to it. I will have to break the weld at the pump that is why I wanted to know the pickup lenth in case I had to go with plan B.
So I can assume that the oil pan on this motor is the same size pan that is on a truck (like a suburban with a 454).
Scott is offline
Old 06-02-2003 | 11:47 AM
bobby daniels
the truck pick up I use is from a chevy like a 50 series big block from 70's or 80's I can send one if needed
tomcat
38
03-09-2011 08:04 AM
Noise Pollution
1
11-20-2007 10:33 PM
fandango
05-17-2007 04:31 PM
GNJ
14
11-12-2006 10:58 AM
dodsonartic1
2
06-27-2005 09:54 AM
