Weight of a 454???
Can anyone tell me the weight of a 454?
(Yes I should know this, but I forgot.)
PS -- I know this isn't a political question, but I hope it isn't considered too far "off topic".
from Outdrives.com;
MerCruiser 7.4L MPI Specifications
Propshaft Horsepower: 310 (232 kW)
Displacement (Liter/CID): 7.4L/454
Cylinders: V-8
Bore & Stroke (inches/mm): 4.25 x 4.00/108 x 101
Compression Ratio: 8.9:1
Fuel System: MPI
Full Throttle RPM Range: 4200-4600
Ignition Type: MEFI/EST Digital
Alternator: 65/917
Length (inches/cm): 39/99
Width (inches/cm): 32/82
Height (inches/cm): 24/61
Weight (lbs./kg) - Alpha: N/A
Weight (lbs./kg) - Bravo One: 1158/525
Weight (lbs./kg) - Bravo Two: 1170/531
Weight (lbs./kg) - Bravo Three: 1179/535
Weight (lbs./kg) - Blackhawk: N/A
Gear Ratio - Alpha Drive (primary/optional/high altitude): N/A
Gear Ratio - Bravo One (primary/optional/high altitude): 1.5/1.36/1.65
Gear Ratio - Bravo Two (primary/optional/high altitude): 2.0/1.81/2.2
Gear Ratio - Bravo Three (primary/optional/high altitude): 2.0/1.81/2.2
Gear Ratio - Blackhawk (primary/optional/high altitude): N/A
Cylinders: V-8
Fuel System: MPI
Alternator: 65/917
1BIGJIM
1
04-02-2007 06:23 PM
lhousman
13
03-05-2002 01:47 AM
