496-Motor 375hp or 425hp? >
Old 03-23-2003 | 07:34 PM
Hi Guys,
How can you tell if your 496 is 375hp or 425hp?
I have the block number(12558110) but do not know how to find out what the horse power is? Is there a web site that can tell me this? Thanks, Susan
fountainsue is offline
Old 03-23-2003 | 07:40 PM
cuda's Avatar
They make both. The mag is 375 hp and the mag ho is 425 hp.
cuda is offline
Old 03-23-2003 | 07:57 PM
I know that make both.... The blond hair is out of the box !!!
My question is; can you tell which HP it is by the block number.
And if you can't, what numbers of the engine do you need to find out...
Thanks again,
Old 03-23-2003 | 09:33 PM
SeaRay Jim's Avatar
Doesn't the Mag and the Mag HO have different engine covers and HO is on the engine cover itself?
And anohter guess, is doesn't the HO come with closed cooling system?
SeaRay Jim is offline
Old 03-23-2003 | 09:49 PM
If you want to check it by the serial #, you have to get the Merc serial # off the back of the engine block near the starter.
BTW, if it says 496Magnum its 375hp. If it says 496Magnum HO its 425hp. It should say so right on top of the engine cover.
Griff is offline
Old 03-24-2003 | 07:47 AM
ccarloss's Avatar
It may also say it on your ECU. My ECU has a sticker that says 496MAG HO followed by a bunch of numbers.
ccarloss is offline
Old 03-25-2003 | 07:29 PM
Thanks for all the help!!!!!!!!!!
Lake St Clair is almost back to water.....
Will be boating soon!!!
DesertRage
Swap Shop
13
08-29-2021 10:02 PM
aquafun
07-17-2008 09:00 PM
NoQuarter
Baja
8
07-12-2007 09:12 PM
rhory
5
11-04-2004 12:03 PM
bcoffield
Baja
6
03-19-2002 04:32 PM
