Drive Oil Change Pump >
Old 03-24-2003 | 02:42 PM
Default Drive Oil Change Pump
Who makes a good gear oil hand pump with a decent size reservoir. I'm tired of the plastic Merc thing.
floatingphil is offline
Old 03-25-2003 | 12:18 AM
edb07's Avatar
Try Stevens Instrument Company, 111 E Greenwood Avenue
Waukegan, IL_ 60087
phone: (847) 336-9375_, Model S-33 works great. Order connector for Bravo's. Looks like a yard bug sprayer. Stand by when you fill it up ($$$) and make sure the valve cannot be accidently opened or you will fill your trunk instead of your drives. Stevens may have dealer only sale policy. It is well worth the price.
Ed
edb07 is offline
Old 03-25-2003 | 09:25 AM
Thanks,
I'll contact them.
Old 03-25-2003 | 09:33 PM
bob
Charter Member #40
If you want to go first class, Latham makes a piece that they use on their steering systems.
bob is offline
Old 03-26-2003 | 10:23 AM
When My Plastic Mercruiser Pump Broke,I Adapted The Pump Fitting That Screwed Into The Lower Unit Of My SSM#5's To MyReversible Porta-quick Oil Changer. I First Flush The Pump Of Engine Oil And Use A Clean Container I've Marked To Indicate How Many Quarts Of Lube Is Pumped Into The Lower Unit. I Slowly Turn The Prop Shaft While The Lube Is Going In To Avoid Air Pockets. Just Trying To Help!
Lmarth is offline
wieland77
21
09-04-2008 09:23 PM
cloudmaster_321
12
08-08-2007 10:30 AM
BeakBoater35
4
08-29-2005 08:33 AM
thunderdan
5
03-24-2005 06:13 AM
Stormrider
25
04-02-2004 03:59 PM
