What guages should EVERY boat have??? >
Old 03-24-2003 | 09:18 PM
Audiofn's Avatar
Charter Member #232
Default What guages should EVERY boat have???
I am re-designing my dash and I am wondering if I am missing any guages that I should have?
For each engine I will have
1 water temp
2 water preasure
3 oil preasure
4 oil temp
5 tack
Also I will have Voltage, speedo, fuel.
Am I missing any important ones?
Jon
Put your best foot forward!
Audiofn is offline
Old 03-24-2003 | 09:25 PM
LapseofReason's Avatar
If you are doing a new dash I would put a red light that will come on if something is not right, you might not see low oil psi as fast as you will see the light come on to warn you.
LapseofReason is offline
Old 03-24-2003 | 09:26 PM
Drive temp is nice too.
Boost if needed and exh. temp
Old 03-24-2003 | 10:04 PM
Audiofn's Avatar
Charter Member #232
I have the Gaffrig Red Line guages. Some of them do not come as redlines but oil preasure, water temp, fuel level do.
Jon
Audiofn is offline
Old 03-24-2003 | 10:21 PM
Not a line on the gauge, a red light that will come on put them up at the top of the dash so you will see it.
Old 03-24-2003 | 10:40 PM
Boost man
Back4More is offline
Old 03-25-2003 | 12:06 AM
puder's Avatar
speel chekk this fokker!
fuel PSI, maybe EGT, i have dual oil PSI one electric, one mech
Pardon me, while I whip this out!
puder is offline
Old 03-26-2003 | 07:28 AM
mcollinstn's Avatar
Speedo
GPS Speedo
Tach
Hour Meter
Oil pressure (from pump)
Oil pressure (going back into the block after filter/cooler)
Oil temp (from pump)
Oil Temp (going back to block after filter/cooler)
Ammeter
Voltmeter
Water Temp (block)
Fuel level
Fuel pressure
Boost (in the box)
Boost/Vacuum (in the intake)
Drive temp
Intercooler discharge water temp
Water pressure (after the raw pump)
Water pressure (in the block)
EGT (dual needles)
Air Fuel Ratio
I'm sure there's more
mcollinstn is offline
Old 03-26-2003 | 01:06 PM
Raypanic's Avatar
I cant believe you guys dont have one of these! I have a recall switch on mine too
Ray
Raypanic is offline
