Engine Height >
Engine Height
Engine Height
Old 03-28-2003 | 12:02 PM
Official OSO boat whore
Default Engine Height
I need to build a new deck lid for my boat. While building the deck, I want to make accommodations for any future engines. My question is how tall is a x:71 supercharger? Can somebody give me a dimension from the intake valley to the underside of the air cleaner? Please note if you are including a super chiller and how tall it is. Thanks!
Cord is offline
Old 03-28-2003 | 12:06 PM
Zoomnfun's Avatar
I think the Blower Shop site has specs, give a try.
Zoomnfun is offline
Old 03-28-2003 | 12:15 PM
I searched the site, but came up empty handed.
Cord is offline
Old 03-28-2003 | 01:38 PM
BigJake's Avatar
I don't know if this helps. But here are some specs from Keith Eickert site on his engines with blowers.
ENGINE SPECIFICATIONS FOR THE 675 HP EFI ENGINE
AREA SPECIFICATION
Displacement 540 Cubic Inch
Cylinders Eight (8)
Bore & Stroke (inches) 4.5 X 4.25
Compression Ratio 8.3 to 1
Full Throttle RPM Range 5400
Ignition Type MSD/EFI Technologies
Alternator AMP 90 Amps
Spark Plug & Gap R-5671A-8 NKG Gap: .030
Recommended Oil Change Interval Every Ten (10) Hours
Recommended Oil Type 20W50 Kendall
Recommended Oil Filter Fram HP4
Fuel Requirements Minimum: 89 Octane
Recommended Supercharger Lube 80W90 Non-Synthetic
The Blower Shop 871 Supercharger
Dimensions Height 31.5"
/ Width 28.5" / Length 37.5"
ENGINE SPECIFICATIONS FOR THE 1000 HP EFI ENGINE
AREA SPECIFICATION
Displacement 572 Cubic Inch
Cylinders Eight (8)
Bore & Stroke (inches) 4.560 X 4.375
Full Throttle RPM Range 6000
Recommended Oil Type Mobil 1 15W50
Recommended Oil Filter K&N HP5001 or Fram HP6
Fuel Requirements 93+ Octane
The Blower Shop 1071 Supercharger
Dimensions Height 37.75"
/ Width 28.5" / Length 45.5"
ENGINE SPECIFICATIONS FOR THE KE POKER RUN RACE ENGINE
AREA SPECIFICATION
Horsepower 1100 / 1200
Cylinders Eight (8)
Full Throttle RPM Range 6400
Spark Plug & Gap R-5671A-11 NKG Gap: .025
Recommended Valve & Valve Train Change Every Forty (40) Hours
Fuel Requirements 1100 - 93+ Octane / 1200 - Race Fuel (C16)
The Blower Shop 1471 Supercharger
Dimensions Height 40.25"
BigJake is offline
Old 03-28-2003 | 01:48 PM
Ratchet's Avatar
Here is some weiand info.................I'd assume it'd give you a good idea:
http://www.holley.com/HiOctn/TechSer...o/SCTech3.html
Ratchet is offline
Old 03-28-2003 | 03:39 PM
Ratchet-that's PERFECT! But, I want to thank all of you for your help!
Cord is offline
Old 03-28-2003 | 09:08 PM
Cord, are you going to have this thing ready for the Oshkosh pokerrun?
RonS is offline
Old 03-29-2003 | 09:13 AM
The hatch? Proably not. Hopefully, I'll have some hours on the boat and the bugs worked out. Hopefully, I won't have broken by then.
Cord is offline
Commandomatt
Donzi
1
08-23-2008 01:36 AM
mikesufka
05-03-2007 09:30 PM
Toffen
09-26-2006 05:42 PM
Toffen
Prop Talk
4
03-28-2006 11:51 AM
apache21
Skater
3
09-26-2003 12:30 AM
