Boat wiring color codes (edited) PRINT THIS OUT! >
Old 04-04-2003 | 02:02 PM
Wally's Avatar
Were doomed!
Cool Boat wiring color codes (edited) PRINT THIS OUT!
With so many problems on boats being electrical most times. And me wiring a new dash right now i thought i'd post this up for everyone so they know where to start from when trouble shooting.
This list is of the most commonly used wire codes used in boats today. I'm sure i might have left one or more out so add to the list.
(Edited)- OK i just found a couple of other pages i had here about wireing and put them all together.....If anyone see's any mistakes or if there needs to be anything added please let me know and I'll change it
Blk -Grounds-General
Blk/Brn -Pump Grounds
Blk/Red -Voltmeter Grounds
Blk/Org -Isolated Accessory Grounds
Blk/Yel -ignition stop
Blk/Grn -Water Level Sender Ground
Blk/Blu -Lighting Grounds
Blk/Gry -Nav Light Grounds
Blk/Wht -Battery Parallel Solenoid
Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
Brn/Red -Pumps, Bilge or Sump
Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
Brn/Yel -Baitwell or Aerator
Brn/Grn -Fresh Water Pump/Water Maker
Brn/Blu -Head Pump
Brn/Vio -Washdown Pump
Brn/Wht -trim pos sender
Red - Battery Feeds Unprotected
Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
Pink -Fuel Sender
Org/Blk -Audio System Feed
Org/Brn -Electric Head-Sanitation System
Org/Red -Wiper Port
Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
Org/Yel -Diesel Pre-heat
Org/Grn -Wiper Stbd
Org/Blu -Communications Equipment
Org/Vio -Navigation Equipment
Org/Wht -Wiper Center
Yel/Blk -Choke - Neutral saftey trans mounted
Yel/Red -Start Solenoid(starting circut), Neutral Safety
Yel/Org -Powered Ventilation, Fans
Yellow -Bilge Blowers -(also alternator DC output)
Yel/Wht -Rudder Angle Sender
Grn/Red -Stop Solenoid/Kill Switch
Grn/Yel -AC Grounding
Green -Bonding
Grn/Wht -Engine Trim in and or tilt down
Grn/Org -Engine Independent Trim down
Blu/Blk -Cabin Lights
Blu/Brn -Oil Temp Send
Blu/Red -Cabin or Cockpit Lights Port
Blu/Org -Engine Independent Tilt Up
Blu/Yel -Lighting Circuits to Remote Send
Blu/Grn -Cabin or Cockpit Lights Stbd
Blu -Instrument & General Lighting
Blu/Vio -Courtesy, Boarding Lighting
Blu/Wht -Engine Trim Outand/or Tilt Up
Light Blue -Oil Pressure
Vio/Red -Eng. or Generator B+ from Breaker
Vio/Yel -I/O Trim Up (ballast bypass)
Vio/Grn -I/O Trim Down
Vio -12v Ignition-Generator or Engine
Vio/Wht -Trim "Trailer" switch
Gry/Blk -Mast Light
Gry/Red -Spotlight Remote
Gry/Org -Docking Lights
Gry/Grn -Strobe or Beacon
Gry/Blu -Spreader/Flood Lights
Gry/Vio -Windlass/Winch
Gray -Navigation (running) Lights, Tach. Send
Gry/Wht -Anchor Light
Wht/Brn -Temp. Alarm or Indicator
Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Org -Fire Alarm or Indicator
Wht/Yel -Air Flow Alarm or Indicator
Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Blu -Oil Press Alarm or Indicator
Wht/Vio -Voltage Alarm or Indicator
White -General Alarm Usage, Yamaha Kill Switch
Tan - Water Temp sender
Tan/Blu -Warning system sense wire (Audio warning)
Pink -Fuel sender
-Wally
Wally is offline
Old 04-04-2003 | 02:40 PM
Wally's Avatar
Were doomed!
ttt with the edited version!
-Wally
Wally is offline
Old 04-04-2003 | 02:42 PM
This might help too:
http://www.marinemechanic.com/site/page101.html
Gary
Gary Anderson is offline
Old 04-04-2003 | 02:50 PM
wally,
Did you get my e-mail i sent you?
Rick
scarabrick is offline
Old 04-04-2003 | 03:38 PM
Wally's Avatar
Were doomed!
Originally posted by scarabrick
wally,
Rick
Yes i did THANKS! Never knew how big a difference there was!!!
-Wally
Wally is offline
Old 04-04-2003 | 04:11 PM
Default Thanks
I am pulling my MPI motor this coming week & installing a HP500 Carb motor. These color codes will help big time .
John
Johno is offline
Old 04-05-2003 | 12:00 AM
SteveDavid's Avatar
Charter Member #1093
Thanks Wally!
SteveDavid is offline
klaw
3
05-06-2008 02:00 PM
US1 Fountain
Fountain
3
11-03-2005 06:46 PM
L9X25
Velocity
1
08-28-2004 09:36 AM
US1 Fountain
Fountain
4
02-08-2004 01:40 PM
klaw
1
07-01-2002 08:21 PM
