Light bulb or drain them ???
It hit 85* here last week,
and like an over anxious kid,
I dewinterized, and changed
my sea pump impellers.
Needless to say, now I have 2
engines full of water.
Now it's 34*, suppose to get
down to 24* tonite,
do you guys think a drop light
will keep them warm enough ?
or should I drag it down to the shop
and drain them ?
The forecast says a low of 17*
monday night, but I don't really
think the weather people's "crystal ball"
works that far ahead.
Going to LOTO tomarrow to do
some comcrete work, so I gotta,
make a descision soon.
jt
down to 24* tonite,
and drain them ?
jt
If it only gets down to 24, the drop light would probably be ok. Is it suppose to warm up any tomorrow up there? If it's going to get down to 17, I personally wouldn't risk it. You will be kicking yourself in the a$$ if you have a problem... Just my opinion.
Dean
Dean
If it were going to be 24 for more than a day, then you should be worried, 24 as a low, that mean below 30 for maybe 6 hours...not enough to freeze up a block, If your worried, throw a light bulb in there.
Official OSO boat whore
I did the light bulb thing this past fall. I also pushed the freeze plug out of the block. How much does it cost you to drain and antifreeze the engine? How much does it cost to rebuild your engine due to a cracked block or cooler?
Thanks for the input guys,
I 've made an executive descision,
and decided to do what any lazy,
procrastinating S.O.B. would do.
Once the
turned on.
........... Take it down to the shop,
and leave it inside all weekend.
I'll deal with it sunday night after
I get back from the lake.
Hell by then, the forecast may change.
I may have torn up some grass at
my friend house, getting her out,
but grass will grow back, all
that black and blue stuff won't
Once the
turned on............ Take it down to the shop,
Buy a small ceramic heater at home depot. If they are safe enoungh for a house they are plenty safe for the bilge of a boat and it has an adjustable thermastat. Otto
That happened to me last year, so I took my plug in little space heater tossed it in engine bay and let it stay on low all weekend. Everything was fine. Freezing cold here In Philly today going down to 20's again tonight.
