Best Hull support location from boat lift bunks?? >
Old 04-06-2003 | 07:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Best Hull support location from boat lift bunks??
Which is the best width location to place the bunks from a hydro hoist lift as far as hull support? Stability is not the issue as either is fine, the location of where the hull is the strongest is my question.
2 choices,
1st is at 36" outside to outside, closer to the keel. Or
2nd is 67" outside to outside of the bunks, closer to the sides.
Lengths will be the same.
Both of these locations are from my Eagle trailer bunk locations which will place the lift bunks along the chines and trap the boat straight.
US1 Fountain is offline
Old 04-06-2003 | 08:33 PM
formula31's Avatar
lve always figured the strongest part of the bottom is where the stringers are. Dont know if that helps.
formula31 is offline
Old 04-06-2003 | 08:37 PM
bobby daniels
just be sure the bunks run past the transom this is very important !!!!
Old 04-07-2003 | 10:45 AM
US1 Fountain,
When I set mine up I placed them directly under where the stringers are. I also never put it on the lift or trailer unless there is bunk out past the transom. If you leave the boat hanging over either I feel that over time it may develope a hook in the hull due to the unsupported weight. I also have 2 bunks per side (total of 4) instead of the standard 2 per side. I figured it would dissipate the weight over a larger area and give more and better support. Have been very happy with our Hydra Hoist.
Mark
GETTINBYE is offline
Old 04-07-2003 | 09:58 PM
Ginger or Mary Ann?
Thanks guys. I checked the boat today. Luckly, there are stringers at both of my choices. Life is GOOOOOOOOOD!
Old 04-07-2003 | 11:11 PM
Tonto's Avatar
Get yourself a MYCO craddle for the lift. Gives great support and centers the boat every time. You will not be disappointed.
Robert
Tonto is offline
Ron P
07-15-2007 08:32 PM
HiPerf2000
11-03-2006 01:55 PM
Formula Outlaw
09-28-2004 08:44 AM
JimmyBaja
4
02-03-2004 07:41 AM
