Electric Fuel Pump >
Electric Fuel Pump
Electric Fuel Pump
Old 04-08-2003 | 06:42 PM
convincor's Avatar
Default Electric Fuel Pump
Did a search on this and have found many different answers.
What should I run for a stock 502 gen VI.
Changing from mark IV 454 so I had mechanical.
How are the Holley pumps?
convincor is offline
Old 04-08-2003 | 06:55 PM
Aeromotive gets my vote.
DAVE
Dave F is offline
Old 04-08-2003 | 07:23 PM
28SCARAB's Avatar
I use the Mallory comp 140 marine pump keeps my fuel pressure at 8psi on my blower motor
28SCARAB is offline
Old 04-08-2003 | 07:30 PM
Elite Marine's Avatar
Default Aeromotive
This pump is good up to 1200 HP, flows 500 Lbs/Hr at 45 PSI. Recommend a 100 Micron filter after the pump to protect injectors.
Elite Marine is offline
Old 04-08-2003 | 07:40 PM
convincor's Avatar
I'm running carb.
Old 04-08-2003 | 07:42 PM
seahawk's Avatar
I just did the same thing (454 to 502) use holley blue w/ oil pressure safety switch.
seahawk is offline
Old 04-08-2003 | 07:54 PM
convincor's Avatar
Why blue over red.
I think the Red would be enough, no??
Old 04-08-2003 | 08:16 PM
28SCARAB's Avatar
I used the same comp.140 pump when I had the 502 carb. GEN.5
28SCARAB is offline
Old 04-09-2003 | 10:09 AM
Mallory 110 or 140. I've had no problems with Mallorys at all.
Be sure to use an oil pressure switch.
Gary
Gary Anderson is offline
Old 04-09-2003 | 11:36 AM
26scarab's Avatar
I run the Mallory 140 with no problems , although the next time I would go with a Aeromotive or Weldon.
Don't waste your time with the Holleys, in the race car day's I had nothing but problems with them. And if they worked they were noisey as hell.
26scarab is offline
