Pyrometers
Old 04-09-2003 | 02:27 PM
MY OBSESSION
Question Pyrometers
I AM RUNNING A 25' OBSESSION CAT WITH A 525SC. A FRIEND TOLD ME THAT I SHOULD INSTALL A PYROMETER WITH A SUPERCHARGED ENGINE. CAN ANYONE TELL ME IF I NEED ONE, AND IF I DO SHOULD I HAVE THE SENSOR/PROBE PROFESSIONALLY INSTALLED???
Old 04-09-2003 | 03:10 PM
bobby daniels
Yes it comes in handy we do it on alot of boats but its not mandatory,for sure .
But if you chose to use one do get it welded in by a good welder
but other than that its easy to install
Old 04-09-2003 | 03:17 PM
Kanookstr's Avatar
32' SUNSATION
I Swear by them in my Procharged engines.
Kanookstr is offline
Old 04-09-2003 | 03:34 PM
X-Rated30's Avatar
WTF is a pyrometer???
X-Rated30 is offline
Old 04-09-2003 | 03:37 PM
rjcardinal's Avatar
Pyrometer = exhaust gas temperature meter. Used to dial in air fuel ratio.
Ron
rjcardinal is offline
Old 04-09-2003 | 04:07 PM
Mrgoodwrench's Avatar
pimpthis.com
Its the most important guage on my console. Tells you alot about whats going on inside. It does require drilling of the exhaust manifold. Best to have a bung welded on too.
pimpthis.com
Mrgoodwrench is offline
Old 04-09-2003 | 06:32 PM
I have 4 of them on my boat ! 1 for each side of each motor ...... great to have ! IF it gets hot you know something is wrong before you blow it up !
boot is offline
Old 04-09-2003 | 06:36 PM
I shouldn't brag ....... Mine came that way ! It has spacers between the heads and exhausts that have threaded ports to screw the probes into . They read a touch hot there as you are in the direct heat of the flame but they get the point across . Idealy you should be about 3-4 inches outside the port in the ehaust tube .
boot is offline
Old 04-09-2003 | 07:27 PM
Best thing I EVER put on my Skater. Like was said earlier, it really gives you an accurate depiction of what is going on inside. A few things to remember. Accurate placement is of paramount importance for proper reading. Secondly, install one probe for each bank if possible, then you know what each side of the motor is doing. Lastly, DO NOT cut the wires and READ THE DIRECTIONS READ THE DIRECTIONS READ THE DIRECTIONS! You will not regret having them. Good luck.
Shane is offline
Old 04-10-2003 | 12:00 PM
Primal Instinct's Avatar
Question
I was looking at a boat yesterday that had pyrometers. When I asked questions, the mechanic also talked about oxygen meters or something like that. What are they, where do they mount and where do you buy them? Thanks for the help!
Primal Instinct is offline
Bad Girl
12
05-29-2006 08:48 PM
ratman
11
07-05-2005 08:57 PM
shawn
14
10-18-2004 03:17 PM
shawn
2
09-15-2004 12:24 AM
