502 carbed spark plugs >
Old 04-09-2003 | 07:01 PM
racinbird
Default 502 carbed spark plugs
I need some help please! I just purchased a used 97 baja boss with a built 502. Im going to do a tune up here soon and want to know what spark plugs are best for this application. It is a performance built engine close to the 500HP(?) specs, around 500 hp and 575 lbs-ft and has a carb. The plugs that are in it are Champion RV15YC4 and look to have worn normally. Any one with a carbed 502 out there have any suggestions? that would be great. thanks Derrick
Old 04-09-2003 | 07:14 PM
convincor's Avatar
Not sure with your application, but i've had real good luck with Bosch Platinums in mostly stock engines.I use them in everything i own.
Found a conversion chart that list all brands if you need it.
convincor is offline
Old 04-10-2003 | 03:52 AM
AC Rapid Fire #1's worked very well for me.
Griff is offline
Old 04-10-2003 | 03:44 PM
obnoxus's Avatar
Charter Member #1171
They get my vote to.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-05-2004 | 11:28 AM
Default Re: 502 carbed spark plugs
do you still have chart?
mark linger is offline
Old 08-05-2004 | 12:24 PM
Official OSO boat whore
A MR43T is a very popular marine plug. I too run the platinums in my street vehicle, but I havn't been able to cross reference to a marine plug. The MR's have a stainless body so they won't corrode.
Cord is offline
Old 08-05-2004 | 03:17 PM
DENNIS IF THE ENGINE HAS GM IRON HEADS OR EVEN MERLINS WHAT I USE HERE AT THE SHOP ARE NGK YR5 THIS IS THE PLUG I USE EXCLUSIVELY AND WE BUILD ABOUT 2 ON A MONTHLY BASES WITH NEVER A PROBLEM WITH THAT PLUG. HOPE THAT HELPS LAZ MESA WWW.MESABALANCING.COM,
MESABALANCING is offline
Old 08-05-2004 | 08:15 PM
MACDAD260's Avatar
Charter Member #818
Those Champion plugs will work just fine. They have an extended tip so they will not foul easily if you do a lot of idling. I have them in my 502 and they work great. I doubt if a more expensive plug will make any difference in how it runs.
MACDAD260 is offline
Old 08-06-2004 | 12:57 AM
What about plugs for aluminum heads.I have to use the ones with the small hex or I can't get a plug wrench on them.Even with the small hex I had to make a custom machined down socket with a universal tig welded to it.I have used champion rc12yc an ac fr3ls.I like to change my plugs a couple times a season just to monitor whats happening in the engine.I have not had any real complaints with either plug.I would like to try a colder one because after a hard run I sometimes get a bit of run on at shutdown.
HARRISONMIRAGE is offline
Old 09-15-2025 | 07:43 PM
Default 1990 baja 250
just curious what spark plugs i should be running in stock 502 jasper motor in my Baja? right now i have NGK R (BR6FS) plugs. Had dads friend who is mechanically inclined that he doesn't think they are right, it thinks i should be running NGKUR4? any input on what i should be using?
Leick238 is offline
