AN fittings angle >
AN fittings angle
AN fittings angle
Old 04-11-2003 | 07:04 PM
Default AN fittings angle
What is the flare angle of an AN fitting? I need to shorten a fuel line and I have a 45 degree flare tool, will that work?
Tim T.
BadDog is offline
Old 04-11-2003 | 08:28 PM
rws's Avatar
rws
AN Fittings are 37 degree, SAE fittings are 45 degree.
Rob
rws is offline
Old 04-11-2003 | 09:00 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Tim, you know any aircraft mechanics? They will have them. Or to where you could just go to small airport and have them flare them while you wait?
When I made up these lines, I priced the AN flaring tools trying to buy a set, not cheap tools.
Then I was reminded I WORK at an airport! Duh!!! What a putz I felt like. 5 minutes later, I had some at my disposal.
US1 Fountain is offline
Old 04-13-2003 | 08:33 AM
US1 has just given you guys a great tip- seek out and make friends with A&P mechanics at your local airports- they are also an avenue to MUCH cheaper prices for your Aeroquip and
Stratoflex fittings and hoses, since they buy this stuff at wholesale prices from aviation dealers. Most shops have boxes full of these fittings and the like.
I just have to shake my head when I look in a Summit or others catalogs and see the prices they charge John Q. Public for that stuff- 3-4 times or more the price we pay in aviation.
Aircraft mechanics don't bite, they just bark a lot!
Jim
jafo is offline
Old 04-13-2003 | 09:41 AM
blown1500
In a pinch, you can 45* flare a steel tubing and use the AN fittings. It will seal and work just fine on a low pressure, non aircraft situation.
Old 04-13-2003 | 10:02 AM
Official OSO boat whore
There are also crimp fittings that use the dreaded compression ring.
Cord is offline
Old 04-13-2003 | 05:37 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
summit racing or jeggs has all the fittings you need
WILDTHING TAZ is offline
Old 04-13-2003 | 07:05 PM
OK, I flared it at 45 (the pipe end) and sanded it with 600 grit. Hooked it up and snugged it till it quit. Sealed right up. I did make it a little long so I can re-flare at 37 when I scare up the tool.
Tim T.
BadDog is offline
38KV
26
02-21-2014 05:36 PM
littledcsrodshop
Saber
5
02-14-2007 04:54 PM
fruitta55
Banana Boat
2
07-25-2006 09:04 PM
fourplaydave69
Fountain
0
12-18-2004 07:14 PM
PhantomChaos
04-26-2002 09:21 PM
