Changing to new style exhaust shutter's... WTF? >
Old 04-13-2003 | 11:41 AM
cig1988's Avatar
Default Changing to new style exhaust shutter's... WTF?
The old style which were all steel with 2 small rubber grommets were no longer available. OK.... went with new style pn#807166a1. Looks like a better set up but how the hell do they go in??? It looks as if the rubber ends need to attach to the shutter and slides in. Tryed a little grease, not happening! HELP?
cig1988 is offline
Old 04-13-2003 | 05:03 PM
formula31's Avatar
Thay are a wiener to get in the older bullhorns. I frequently use a large sanding drum and my drill on the inside of the pipe to open it up slightly.
formula31 is offline
Old 04-13-2003 | 06:51 PM
cig1988's Avatar
So I guess it's a real tight fit... Nothing is ever easy. I have a porting tool I can use for that. Thanks.
cig1988 is offline
Old 04-13-2003 | 07:56 PM
formula31's Avatar
And sometimes you might have to take a little off the end so it goes down far enough to engage the 2 holes in the pipe. Make sure the flappers move freely too. Good Luck
Old 04-13-2003 | 08:53 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Same thing here. Tight as can be. If you install them as is, I believe the frame gets distorted enough that it binds the flappers from working. I sanded the inside of the plastic framework where the flappers touch until she fit without binding.
US1 Fountain is offline
Old 04-14-2003 | 05:54 AM
cig1988's Avatar
What exactly engages into the holes? Looks like the 2 sqaure rubbers just fit over the pre existing holes.
cig1988 is offline
963b
Midwest
1
03-08-2008 09:27 PM
35 White Lightning
Fountain
3
07-20-2007 01:53 AM
duke252
04-17-2007 09:52 AM
pullmytrigger
9
03-25-2006 10:28 AM
45sonic
05-31-2005 12:00 PM
