drive showers, thru hull exhaust, oil >
Old 04-17-2003 | 12:14 AM
pozguy
Default drive showers, thru hull exhaust, oil
I have been reading about drive showers and am thinking about putting one on this summer, is it worth it, I have a 2002 5.0L M.P.I. with an Alpha drive. Simrek sounds the best. I am also thinking about thru hull exhaust, do you get any performance gains or just alot of sound? Which kind are the best? I am also wondering about engine oil, as I am currently using what Merc calls for, Quicksilver 25/40. Would it be better to go to a synthetic, different weight, something like Redline or Amsoil. Thanks alot.
Old 04-17-2003 | 11:21 AM
EX20's Avatar
Go up to the Forums/Boards dropdown and do a search on each subject. There is already a massive amount of info archived on these subjects.
EX20 is offline
Old 04-17-2003 | 01:31 PM
Ratchet's Avatar
quick answer:
1) Drive showers - YES, Simreck = good
2) Thru hull, naybe a little gain = check out stainless marine for the manifolds / risers..........they now have aluminum riser versions, a little more cost effective along with great service & people to help you, not sure how much hp you'll get, but it sure sounds better]
3) synthetic oil - many opinions on this
Ratchet is offline
Old 04-17-2003 | 05:18 PM
220BR
Ratchet, do you really think a 305 will see even "a little gain" with thru hulls. I'd bet against it.
It'd be alot cheaper to install the aftermarket exhaust bellows that opens up when you trim out. Best of both worlds, quiet around docks and more free flowing on throttle.
Old 04-18-2003 | 09:37 AM
Unchained
I bought Simrek's new 11 dump shower for both of my Alphas. On plane the upper gear cases have complete water coverage.
Thru-hull exhaust at the very least will give you great sound.
I use a quality SAE 40 oil in my small blocks. I change the engine oil and outdrive gear oil every 30 hours.
Old 04-21-2003 | 11:47 AM
Ratchet's Avatar
Talking
Na, probably not much of a gain.......................
I musta misread, I thought he was lookin for more sound..........
Quiet around the docks ? never really considered that to be "the best" of that world
No pun intended - lol
Ratchet is offline
papawayne@comcas
Drives and Lower Units
26
07-13-2010 08:18 PM
raytart
Nordic
2
05-24-2008 08:46 PM
JJONES
9
10-24-2004 04:31 PM
ash72201
01-07-2004 04:04 AM
CAP071
5
04-12-2002 01:40 AM
