Oil Pan bolt torqe? >
Oil Pan bolt torqe?
Oil Pan bolt torqe?
Old 04-22-2003 | 06:51 AM
Default Oil Pan bolt torqe?
What are oil pan bolts supposed to be torqued to?
THRILLSEEKER is offline
Old 04-22-2003 | 07:38 AM
Which gasket, cork or rubber? Usually they are torqued until the pan bends a bit and leaks between all the bolts, that is the way I see a lot of them.
BadDog is offline
Old 04-22-2003 | 07:50 AM
cork.
Old 04-22-2003 | 09:43 AM
Merc Manual from 89, not sure if they used cork in 89 or not.
1/4 - 20 80 in. lbs.
5/16 - 18 165 in. lbs.
I would not tighten any more than what just barely deflects the pan. Watch it closely or use a straight edge. A softer gasket will take less torque. Each brand of cork gasket will compress differently. Take your pick on sealants.
BadDog is offline
Old 04-22-2003 | 10:58 AM
JUSTONCE's Avatar
I'd use rubber gaskets personally, Make sure you tighten them in a cross patern not in a row.
JUSTONCE is offline
Old 04-22-2003 | 11:36 AM
cheitman
Tighten them till they strip and then back a quarter turn! Actually, I use a nut -driver and tighten about as tight as I can in a cricc-cross pattern and usually have no leaks.
Old 04-22-2003 | 02:03 PM
Infomaniac's Avatar
Tighten until the gasket starts to push out and stop there.
Infomaniac is offline
Old 04-22-2003 | 05:20 PM
formula31's Avatar
Cast or stamped pan?
formula31 is offline
Old 04-22-2003 | 08:23 PM
f31, its stamped
ak
6
06-01-2008 10:45 AM
merlin
Wanted
4
02-26-2008 07:26 AM
eliminatethis
5
08-01-2007 08:57 PM
Wilks
3
06-05-2006 07:51 PM
Mange
9
12-12-2005 12:28 PM
