What paint to use...K-Planes? >
Old 04-25-2003 | 06:46 AM
Default What paint to use...K-Planes?
I need to repaint a plane assembly, any suggestions on paint and primer? I am thinking epoxy primer and paint??
THRILLSEEKER is offline
Old 04-25-2003 | 03:22 PM
ROUGH WATER's Avatar
probley powder coat or emron would be best but i did my drives in normal single stage automotive enamel, lost a min amount of paint in poorly sanded areas, im gonna do it again on my k-planes but sand blast first, should stick good then,
ROUGH WATER is offline
Old 04-25-2003 | 04:35 PM
HyperBaja's Avatar
Not sure on paint, just be sure to keep those away from forklifts
Ready for the boating season yet?
Tommy
HyperBaja is offline
Old 04-25-2003 | 06:27 PM
convincor's Avatar
AWL-GRIP ??
convincor is offline
Old 04-25-2003 | 08:08 PM
cig1988's Avatar
Zinc oxide primer and IMRON!!!
cig1988 is offline
Old 04-25-2003 | 08:56 PM
H2Xmark's Avatar
check to see if it is rated below the water line, most are not, epoxy paint is some great stuff it will hold up great
H2Xmark is offline
Old 04-26-2003 | 06:45 AM
cig1988's Avatar
Personelly, I prefer the IMRON way vs powder coating. Here in the salt water enviroment corrosion is inevitable. IMRON is alot easier and less expensive to refinish long term. 7 years ago I did my cig & still looks good. Holds out much better than the stock merc paint.
cig1988 is offline
SLINGSHOT
Detailing, Painting, & Fiberglass
8
09-06-2011 08:10 AM
shaun harrington
Wanted
0
03-24-2008 03:56 PM
