Outdrive alignment?????
Old 04-26-2003 | 06:41 PM
Default Outdrive alignment?????
OK boys, just heard this one, tell me what you think:
Heard that on V-hull boats, the drives should be aligned slightly towed-in to compensate for the tendency of the V-hull to send the water outward.
Now, I have never heard of this theory before and I personally do not subscribe to it. However, maybe I should.
So,,,,,,,,,,,,,hyperbole or fact??????
ThirdBird is offline
Old 04-26-2003 | 07:43 PM
Ron P's Avatar
Enjoy the show
You can test with GPS to find if there is any speed difference. I heard it too and we always had a 1/2 inch toe in from the nose to the end of the propshaft. Its very slight.
Ron P is offline
Old 04-26-2003 | 07:53 PM
Jimboat's Avatar
Default Toe in
On tunnel boats, I've seen best experience with about 1/4" toe in used. Vee-hulls likely need a bit more.
Jimboat is offline
Old 04-26-2003 | 10:10 PM
Well, had I bet on this one,,,,,,I would have lost!! I really thought this was a bunch of bologna.
I suppose it makes some sense logically that the water from under the boat is being thrust outward, but I didn't think it would make enough difference to require slight drive toe-in. Pretty interesting, never seen anything posted on this before.
Thanks for the responses, I've learned something once again on OSO!!!!!
Old 04-26-2003 | 11:43 PM
Ron P's Avatar
Enjoy the show
Nah, we were just screwing with ya. No one ever toe's em in. I think?
Ron P is offline
Old 04-27-2003 | 06:19 AM
Rick#29
Each hull is different I've done alot of testing ,If you have really big motors the tork of the motors can make the drives twist a little you have to test to find what is write for your boat 1/4 in to a 1/4 out. Moving It 1/8 at a time All in the same water conditions will make it the best for your true drive alginment.
Old 04-27-2003 | 06:21 AM
What the heck dudes??????? Are these answers serious or just kidding?? I can't quite figure out the deflections in your answer RonP.
Old 04-27-2003 | 06:36 PM
CESSNA
I did alot of reaserch on this ,,they need toe in
Old 04-27-2003 | 07:09 PM
Madcow's Avatar
Was having slight handling issues on my boat last year. Come to find out mine where toed in about an inch. I straitened them out and are planing on splashing this week. I'll let you know the results
Madcow is offline
ThirdBird
7
05-12-2009 07:44 PM
CN24
1
04-12-2007 02:03 PM
rssteiny
0
06-10-2004 07:47 AM
BillR
Powerquest
2
03-01-2004 11:36 AM
olemissalum
24
02-27-2004 06:03 PM
