Normal water Pressure for 500EFI??? >
Old 04-27-2003 | 06:32 AM
Senior Member # 68
Default Normal water Pressure for 500EFI???
Just installed Gaffrig water press. gauges....And when running the engines on the hose through the fresh water flush,the gauges are only showing 1 lb of pressure.At idle up to 2000rpm. the press. stays the same.....I tappped into the thermastat housing,where the water flows between the intake manifold and the inlet side of the circulating pump.Is this the wrong place to tap in????
Steve
Steve A.K.A RAMPAGE is offline
Old 04-27-2003 | 11:26 AM
bobby daniels
Mikes pressure is where you need to be !
Old 04-27-2003 | 12:27 PM
Senior Member # 68
Mike,
Are your gauges electric or mechanical???Where do you tap in at ,at the engine for your pressure????
Steve
Old 04-27-2003 | 10:48 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Most all Fountains I've seen, including mine, have the pressure hose hooked up at one of the side block drains.
US1 Fountain is offline
Mikey Likes It
4
03-06-2007 02:15 AM
BajaRunner
2
09-18-2006 04:26 PM
justinVIP
1
11-17-2003 02:16 PM
Rambunctious
5
07-08-2003 01:21 PM
blown formula
3
08-27-2002 12:12 PM
