Poll:  Guess whats wrong with my Engine. >
View Poll Results: Engine Problem on 350 Mag
Bad Head Gasket
46
32.86%
Cracked Head
35
25.00%
Cracked Block
22
15.71%
Intake Problems
5
3.57%
Other
32
22.86%
Voters: 140. You may not vote on this poll
Old 04-27-2003 | 03:09 PM
TEAMBAJA's Avatar
Default Poll: Guess whats wrong with my Engine.
Pulled all the plugs out of my 350 Mag and water shot out of the #3 cylinder like a high pressure garden hose.
Vote on what you think the problem is, and I'll post after its fixed.
TEAMBAJA is offline
Old 04-27-2003 | 04:18 PM
BUMMER! Sounds like quite a few of us wont be making it to the islands anytime soon
THRILLSEEKER is offline
Old 04-27-2003 | 04:30 PM
OSOsweet
I could have come in via an exhaust issue.. It's easy to pressure check the exhaust first then take the motor apart. Good luck
Old 04-27-2003 | 06:49 PM
FFO
Yes I agree with OSOsweet.. My dad's boat had same problem . It was the exhaust manifold. He had it pressure checked it was cracked. If I were you I would check both.
FFO is offline
Old 04-27-2003 | 07:12 PM
CheckmateF1's Avatar
Charter Member #355
I vote cracked manifold.
Boatless in Texas......for now
CheckmateF1 is offline
Old 04-27-2003 | 07:50 PM
Dave1972's Avatar
It is probably not an exhaust manifold. If the manifold was cracked it would not allow THAT much water into the motor. For water to reach the piston it would have to go back through the cylinder head, through the exhaust valve and into the combustion chamber while running. Sounds like a head gasket or possibly an intake manifold gasket/bolt issue to me. Would love to hear what it is when you get it fixed. Good luck regardless!!!
Dave1972 is offline
Old 04-27-2003 | 08:49 PM
TEAMBAJA's Avatar
Did a pressure check tonight on all the cylinders. The one thats blasting water out is about 30-40# higher than all the others.........
TEAMBAJA is offline
Old 04-27-2003 | 08:57 PM
compression or leakdown test?
Old 04-27-2003 | 09:57 PM
TEAMBAJA's Avatar
Compression
TEAMBAJA is offline
Old 04-28-2003 | 09:21 AM
28SS's Avatar
check your exhaust valve spring.
28SS is offline
