trailer ball nut coming loose >
Old 04-27-2003 | 03:28 PM
yzbert's Avatar
Exclamation trailer ball nut coming loose
anyone have trouble with there trailer ball nut coming loose? had the problem last year pulling a 32 fountain. torque the hell out of the nut.
now last night driving back from loto, 3 am with my new boat 36 baja, boat seems to start to bump a little, stop and check nut, it is gone. life past before my eye's.
this nut 1 1/4 shaft, tighten by very strong man with big pipe wrench, beat on with slege hammer, and then braised.
wtf
thinking of lock tite-ing nut drilling nut, and pining.
what do you do?
signed
almost dead
yzbert is offline
Old 04-27-2003 | 04:11 PM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
Put a little grease on the ball itself to let the trailer slip on the ball while cornering. If that fails to remedy the problem buy a ball that is welded to the hitch that slides into the receiver. Hope this helps. Grease will usually take care of it. Dont put grease on the bottom side of the ball just the top and upper sides of the ball.
Sean
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 04-27-2003 | 04:33 PM
Raypanic's Avatar
Isn't there a lock washer on it? My balls are always greased well too
Ray
Raypanic is offline
Old 04-27-2003 | 04:49 PM
yzbert's Avatar
yes there is a lock washer on it. will try the grease though.
yzbert is offline
Old 04-27-2003 | 10:17 PM
cuda's Avatar
Is there enough threads to lock another nut against the first one?
cuda is offline
Old 04-27-2003 | 11:11 PM
puder's Avatar
speel chekk this fokker!
crank it down hercules!!!!
Pardon me, while I whip this out!
puder is offline
Old 04-28-2003 | 12:13 AM
buck183's Avatar
We have an impact socket that we use just for trailer balls at the shop. We use it to put on every ball when we install tow packages for customers. Impact gun is rated at 600 ft/lbs. That'll do the job.
Buck
buck183 is offline
Old 04-28-2003 | 02:10 AM
IntolerantOne
Have someone put a weld on it. Cheap and done for good.
Old 04-28-2003 | 03:23 AM
BattleCry's Avatar
Weld It and put the grease on it.
BattleCry is offline
Old 04-28-2003 | 05:11 AM
yzbert's Avatar
ok, impact, weld, grease
yzbert is offline
