Grease
Old 04-28-2003 | 08:00 AM
97BossHammer's Avatar
Default Grease
What all area's do I need to be greasing? Keep in mind your talking to a newbie at owning a boat so I need to know the area's that I need to be watching pretty regularly. The only thing I've mainly been doing is the one on the outdrive.
Also, how often do I need to repack my trailer bearings? They are all packed with caps on them......do i need to worry about these?
Just need to know in general which area's to grease and how often.
97BossHammer is offline
Old 04-28-2003 | 08:37 AM
Audiofn's Avatar
Charter Member #232
are your wheel bearings the bearing buddy type? If so then you just need to keep a eye on them. If they get to the bottom a couple pumps of grease will get ya rolling again. You do not want to fill them all the way up because when the grease gets hot it will push off the buddy or make a mess as the grease goes out the preasure releif valve. From there do a close inspection of your drives and such and look for any grease fittings.
Jon
Put your best foot forward!
Audiofn is offline
Strip Poker 388
22
05-08-2007 08:17 AM
Griz
1
08-17-2006 02:32 PM
chewy1955
2
02-27-2006 04:02 PM
BAD-HABIT
1
04-08-2005 05:33 PM
wwwTOPDJcom
06-13-2002 05:34 PM
