500 EFI fuel lines >
500 EFI fuel lines
500 EFI fuel lines
Old 04-29-2003 | 06:30 AM
rtn137's Avatar
Default 500 EFI fuel lines
Anyone have experience upgrading the fuel lines on the 500EFI?
I'm putting Aeroquip -8 fitttings from the tanks up to the filter but the stock filter has a 1/4" fitting. Any ideas? Is there a better filter that will bolt on? Will this cause any problems?
rtn137 is offline
Old 04-29-2003 | 08:22 AM
Adivanman
Smile HP500EFI Fuel Lines
We used -6 rather then -8 with no problems. There is really no advantage to the bigger line since the fuel filter and cool fuel will ultimately determine flow. I did end up with -8 in the Camaro but it was already there and I wasn't using the cool fuel or filter anyway. Biggest issue to contend with (in the boat) is corrosion (of the anodized aluminum fittings) unless you go with stainless or nickle coated.
Old 04-29-2003 | 08:43 AM
pachangalpina's Avatar
If you feel you need larger fittings on the filter housing, you can drill and retap them to 3/8npt.
pachangalpina is offline
Old 04-29-2003 | 09:09 PM
rtn137's Avatar
I can't believe 500 h.p. is supported with 1/4" line but everyone says you need 1/2" or 5/8" to support 700-800 hp.
I was going to install a Whipple so I was already upgrading the fuel lines to -8 but the whipple system doesn't use the factory fuel filter. Now I'm not installing it so all the fittings and hoses are on up to the factory filter.
rtn137 is offline
Jim Diesel
2
09-03-2008 07:40 PM
Dock Holiday
6
10-10-2007 06:52 PM
Fountain38
2
05-16-2007 05:42 PM
chad1
12-07-2005 12:00 PM
RonS
08-19-2003 08:15 AM
