500EFI Rev Limiters >
500EFI Rev Limiters
500EFI Rev Limiters
Old 04-29-2003 | 01:22 PM
jdnca1's Avatar
Default 500EFI Rev Limiters
I'm sure there have been threads on this issue, but I am looking for the easiest most cost effective way to increase the rev limiters from 5250 to ~5500 on 2000 500 EFI's. Is it possible to reflash the Ecm or should I just convert to MSD ignition, and what's involved there. My current Motor has the MSD 7 ignition and its a simple turn of a dial. thanks in advance for the suggestions....
jdnca1 is offline
Old 04-29-2003 | 01:32 PM
blown1500
The only way to change the rpm limit on a 500efi is to reprogram.
If you will have the ECU limiter placed high or removed, you can use your ignition as the limiter-much easier on the motor as the ECU cuts the fuel, not the ignition. There is no way to take out the ECU limiter without having someone reprogram it that I know of. Arizona Speed and Marine can help.
BadDog
2
08-28-2007 07:46 AM
Donzilla
General Racing Discussion
1
02-23-2005 09:51 PM
jryan26
4
01-17-2004 11:23 AM
34scarab
2
01-13-2004 02:29 AM
THRILLSEEKER
5
07-09-2002 08:46 PM
