Bezel for gaffrig mechanical trim tab indicators? >
Old 04-30-2003 | 07:45 AM
Default Bezel for gaffrig mechanical trim tab indicators?
Does anyone know of bezels that can be put under the gaffrig mechanical trim tab indicators? I'm replacing my boat leveler trim tabs with kplanes and my mechanical indicator is going over the location where the old electronic indicator used to be. The only problem is that the circle diameter of the old gauge is just a little larger (1/8") than the width of my new gaffrig gauge. Any suggestions? I really don't want to do any fiberglass and gelcoat work. Thanks in advance.
Allen
FBRONCO is offline
Old 04-30-2003 | 08:47 AM
Rambunctious's Avatar
don't know of an existing product, but you could find a local lazer cutting manufacturer to cut arectangular bezel out of stainless per your dimensions and then have it buffed, or cut out of aluminum and have it annodized a color.
i am imagining a thin picture frame shaped bezel
just two alternatives
Rambunctious is offline
Old 04-30-2003 | 08:50 AM
ren3
Check with Livorsi, Eddie Marine, and CP Performance.
Old 04-30-2003 | 11:53 AM
26ZX Donzi's Avatar
Livorsi Marine - Ron Harris
847-548-5900 ext 223
26ZX Donzi is offline
Old 04-30-2003 | 06:39 PM
Payton's Avatar
Charter Member #927
They do make a bezel for the indicator plates
Payton is offline
Old 04-30-2003 | 07:27 PM
Audiofn's Avatar
Charter Member #232
Hit their web site I am sure you will see them. If not call them up and get the catallog
Jon
Put your best foot forward!
Audiofn is offline
bigmotor
2
08-11-2008 07:39 PM
Inspector
Wanted
3
03-18-2008 08:47 PM
boatnt
Wanted
3
01-24-2008 11:58 PM
Dave M
2
06-15-2005 07:45 AM
VelocityMark
04-02-2003 04:05 PM
