spark plug gap >
spark plug gap
spark plug gap
Old 04-30-2003 | 06:22 PM
Default spark plug gap
Just bought new plugs, and they are gapped from the factory at 42 thousandsths. Mercruiser suggests 32 thousandsths for my 420 hp engines. how important is regapping the plugs?
thanks.
Chart is offline
Old 04-30-2003 | 06:38 PM
blown formula's Avatar
Are you using Merc ignition & coils? If so, I would gap them at no more than .035. A larger gap, provided you have a "hot" coil produces a larger flame front for more complete combustion. I used .040-.045 on my Jacobs ignition w/MR43T plugs in my blower motors and worked extremely well.
blown formula is offline
Old 04-30-2003 | 06:59 PM
Using merc thunderbolt ignition. Noticed that the 330 was at .035, and the 420 was at .032. Seamed a little odd to me that the lower hp engine would use a larger gap.
looks like a gappin we will go. . . .
Chart is offline
Old 04-30-2003 | 07:58 PM
Sammy
I just picked up a set of NGK's and they said to gap them at.044. That seems a bit wide, what do you think.
THX
Sam
Old 04-30-2003 | 08:02 PM
It's wider than what I've found, but that would prevent regapping 16 spark plugs. What kind of engines do you have?
Chart is offline
Old 05-01-2003 | 03:39 AM
THX
Sam
Who is "they"
Griff is offline
Old 05-01-2003 | 02:06 PM
OBNOXUS21's Avatar
I just gapped my NKG's at .35. Same as what they were gapped at. And as was suggested.
OBNOXUS21 is offline
Old 05-01-2003 | 02:13 PM
Sammy
I'm runing a SBC putting out around 360-370 hp. Griff, " they" are NGK .
Sam
Old 05-01-2003 | 02:48 PM
Luv-N-It's Avatar
Sam
I think he means who are "they" that told you to gap them at that. Dealer, Marina...
Luv-N-It is offline
Old 05-01-2003 | 06:15 PM
bobby daniels
with most ignitions you'll never notice the gap change 35 works great .
On M S D and other high current ignitions they give enough spark energy to take some advantage of the larger gap.
