Trim Switch... >
Trim Switch...
Trim Switch...
Old 04-30-2003 | 07:23 PM
WES311SR1
Default Trim Switch...
I just ordered a "on the throttle" out drive trim switch. does anyone have any hints or comments on installing it . it will be one switch operating both drives.
Old 04-30-2003 | 09:30 PM
mcollinstn's Avatar
You'll have to use a relay or diode to still be able to trim independently with the dash switches.
mcollinstn is offline
Old 04-30-2003 | 09:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Be sure that you use diodes. (Depending on your current dash setup) Otherwise you will not be able to operate them separately.
US1 Fountain is offline
Ginger or Mary Ann?
Me type to slow.
Old 04-30-2003 | 10:30 PM
WES311SR1
I will be installing it on a 91 311 formula . it now has 2 trailer trim switches and 2 reg.trim switches.
Old 04-30-2003 | 10:34 PM
buck183's Avatar
Just put one on the Scarab Sunday. I found it to be a pretty easy install. Wiring was simple and straight forward IMO. Just used the supplied diodes, some heat shrink, and the job was done. Works great! Mine was a single though.
Haven't water tested it yet to see if I'm gonna like it. It looks like it's gonna get in the way of the shift lever just a little bit though.
Buck
buck183 is offline
Old 05-01-2003 | 10:04 PM
Rambunctious's Avatar
wes
i am thinking of the same thing for my formula 272.
but my pumps don't quite run the same speed, so i will install two throttle switches. wondering if forward (finger actuated) or side mount (thumb actuated) will be easier for two switches.
i have to hold one of them 1 extra second to have the drives parallel.
Rambunctious is offline
Old 05-02-2003 | 05:21 AM
Fast Forward's Avatar
Just installed one on my Powerquest with a single. However I did not receive any relay or diode. I wired it off the trim switch in the dash and it seems to work fine. Any idea why the diode or relay are needed??? Mine was a gaffrig switch.
Fast Forward is offline
Sydwayz
07-05-2007 09:40 PM
SCARAB98
1
05-02-2007 09:56 PM
9Hound
1
07-27-2005 05:09 AM
88formula223
05-11-2005 06:41 PM
ccarloss
2
06-10-2003 06:06 AM
