Tahoe Tires - How Big can you go?? >
Old 05-02-2003 | 08:37 AM
Ran-Dom 32's Avatar
Default Tahoe Tires - How Big can you go??
Does anynoe know if a set of BF Goodrich AT KO's 315/75/16 will fit without any type of lift??? - can get a deal on them but don't know if they will fit under the truck '96 2 dooor tahoe-stock 16" rims
Ran-Dom 32 is offline
Old 05-02-2003 | 08:58 AM
Check over on this board...
http://www.coloradok5.com/
BadDog is offline
Old 05-02-2003 | 09:20 AM
racer-x6's Avatar
I think a 305 is all you can fit. (That's what I was told) If it's a 4x4 I was told that you need to change the spare because if you have a flat and put a smaller tire on it will not roll due to the lock up rear end?????
Better check with a dealer. Let us know what you find out .
racer-x6 is offline
Old 05-02-2003 | 11:24 AM
Ran-Dom 32's Avatar
I'm going to try them & see I guess, since there already mounted on same chev rims - I let ya know???
Old 05-02-2003 | 11:29 AM
LapseofReason's Avatar
That tire is 35 inch's tall 12.50 wide.They might fit with 6 inch lift.
LapseofReason is offline
Old 05-02-2003 | 12:17 PM
puder's Avatar
speel chekk this fokker!
i haev 33" tires on my 1500 pickup and they rub the body when you make hard turns. Everytime i park it or make a uturn it make a nasty sound. SO if teh one you want are 35" i'd say they are gonna be to big without a lift
Pardon me, while I whip this out!
puder is offline
Old 05-02-2003 | 03:42 PM
Ran-Dom 32's Avatar
Yep definitely to big - they were on a write off at my cousin's salvage yard - truck had a lift - oh well to bad there like new but I'm not going to lift my truck
Old 05-02-2003 | 05:48 PM
mopower's Avatar
Toxic FORMULA
Ran-Dom,
I had a 95 2dr Tahoe with 305-70x16 on 16X8 Eagle Alloys. So close there is no reason they didn't hit , but they didn't
Sold it for a 98 4 dr and swapped tires...same thing with that.
My eagle alloys had 5" back spacing ( a must , to keep fronts from hitting the fender or bumper when turning). Stock wheels are only 7" wde...a little skinny for 315's even 305's. Both recommend minimum of 8". Besides I don't think you'll get the 315's under it with a lift or at least a little hammer around the edges of the wheel wells
Good luck Dude
mopower is offline
Old 05-03-2003 | 06:58 AM
BFG's 285's fit with no problem. 98 yukon 4x4 4 door and 2003 tahoe 4x4 4dr raised the torsion bars 6 turns then fine tune for level (side to side). don't forget to have the front end aligned!! Any torsion bar adj will require a front end alignment
Rick
scarabrick is offline
Old 05-04-2003 | 08:27 AM
check freak
I had a 99 Z71 2 door tahoe. I had 285 Kelly mud terrains and it really killed the mileage. Of course, I have a lead foot!!! It had a K&N filter and dual flow master mufflers installed, you could really tell the difference in the power. It was a sweet ride!
SCARY31
10-24-2005 05:25 PM
olysan
03-31-2004 08:25 PM
Lou502
05-20-2003 01:52 PM
