Props for TRS and 525s??
Anybody with onfo on how to prop a 30' 5100lb boat with TRS set-ups and 525hp motors?? Motors, trannys, drives are all fresh etc.,the boat is an 83 Sutphen Ocean Pacer. I have 3 blade cleavers with 24p now, but Ive been told a four blade might work better. Also drivability issues would get better. The boat is setup to run around 5000-5300rpm and I'm shooting for mid 80s which I was told is about the max hull speed for this boat without going exotic(read shortened drives, raised transom, boxes) Also, I amy have a chance at a pair of 632s naturally asp. making 850hp...5hours...drop in and go for around 7000 apiece. Would this be a waste in my boat without Going "exotic"?
