? For You Audio Wizards (Jon) >
Old 05-06-2003 | 10:20 PM
Gizmo's Avatar
Are we having fun, yet?
Default ? For You Audio Wizards (Jon)
I have a Clarion AM/FM/CD, ( in the boat ), Not sure of the model #, 515 audio pro, I think. Problem is if I turn the volume up over 18, the unit acts like it has a circuit breaker built in. It will play for a few seconds, then it shuts down for a second or two, then come back on.
Can anyone explain what's going on? And what can I do about it?
Thanks!!!
Jay
Gizmo is offline
Old 05-06-2003 | 10:59 PM
wwwTOPDJcom's Avatar
from my experience that is a low volt condition, can you put a DVM on the power leads going into the stereo and make sure the
Voltage does not drop below 10. volts , I found this same condition on many boats and cars either installed with wrong wire sizes or just a bad connection.
Its still possible that its some power or amp chip problem inside the stereo.
wwwTOPDJcom is offline
Old 05-06-2003 | 11:25 PM
Audiofn's Avatar
Charter Member #232
Both these guys have real likely sollutions. First I would put a ohm meter over the speaker terms and test them (you have to disconnect the wires to do this. If they all test ok then I would check for voltage drops (this is what my money is on) but you still should fallow test procedures
Jon
Put your best foot forward!
Audiofn is offline
Old 05-07-2003 | 07:31 AM
Cignificant's Avatar
It's all those damn blinking lights you're running with the stereo..
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 05-08-2003 | 06:57 AM
Gizmo's Avatar
Thanks for the info guys!! I will do some more investigating.
Steve, The blinking lights wil not stay inthe boat.........
Jay
Gizmo is offline
10x
Northern Illinois Offshore Club
5
12-22-2006 03:10 PM
Shooter
1
10-10-2006 07:33 AM
IM4A2Z
04-10-2006 06:25 AM
hugetime1
08-13-2003 01:49 PM
