What seals a Bravo One upper to the bellhousing? >
Old 05-09-2003 | 12:43 PM
Ranman
Question What seals a Bravo One upper to the bellhousing?
Hello. I recently removed my Bravo One drive and am re-installing it. I've checked and greased the U Joints and gimbal bearing. I also checked the alignment using an alignment tool. All seems well, but what seals the drive to the bellhousing? I see an o ring around the drive oil valve assembly, but that looks like it. Are there any gaskest or seals that need to be replaced when reinstalling a Bravo drive to the bellhousing? The alpha has a gasket that slips over the 6 studs, but I don't see one for the Bravo. Thanks.
Old 05-09-2003 | 01:38 PM
obnoxus's Avatar
Charter Member #1171
O rings on the face of the drive
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-09-2003 | 01:44 PM
Charter Member #415
Just bolt her back on and you are ready to go
Magicfloat is offline
Old 05-09-2003 | 03:42 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Stop by your marina and pick up a Bravo1 installation kit. It only costs a few dollars and includes all the new o-rings and the oblong gasket you need. I just went through this. Also, Merc makes two different kinds of grease, Spline Grease, and U-Joint Grease. I sprung for both. It really helps if you have two people to re-install, unless you are a monster, or have a stand.
Sydwayz is offline
Old 05-09-2003 | 04:09 PM
HiPerf2000's Avatar
The O-ring kit comes with new O-rings for the input shaft, as well as the two (2) that are one the face of the drive where it meets the gimble. there is the one round one that you mentioned around the cable connection, and then there is a square looking one on the other side.
HiPerf2000 is offline
Old 05-09-2003 | 10:48 PM
Waterfoul's Avatar
Gone Fishin'
Originally posted by formulafastech
2 "O" rings on the end of the input shaft, 1 "O" ring for the shift, 1 "O" ring for the drive resovior, and the large rectangular kinda shaped one for the water inlet. Glue on in, and bolt the drive up.
Exactly.
Done it (too) many times. It's a lot easier than you think!!!
'Foul
Waterfoul is offline
Old 05-10-2003 | 02:21 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Dumb question,
but what is the 3rd o-ring for on the input shaft? Never could figure that one out.
US1 Fountain is offline
Old 05-29-2006 | 12:08 PM
Default Re: What seals a Bravo One upper to the bellhousing?
If you have the new style drive coupler, the O ring seals around the extension to help keep the grease in.
kwsundell is offline
Old 06-03-2006 | 10:07 AM
MOP
Lightbulb Re: What seals a Bravo One upper to the bellhousing?
A thin coat of non hardening sealer on the mating surface is a very good idea, I pulled my BravoX with less teh 20 hours in salt water and found a few tiny pits. Water does seep in between the two and will over time cause a corrosion problem.
Phil
MOP is offline
Old 06-03-2006 | 04:18 PM
If you are asking what seals the water from the bellows, it's the edge of the bellows pushing against the forward edge on the upper gear housing. There was a problem with some bellows having too much of a "split line" mismatch causing some water seepage into the bellows, but I think that has been addressed now. The orings on the face are for sealing the shift, water passage, and oil valve.
Falcon is offline
1BIGJIM
8
02-23-2024 05:32 AM
Dave1972
6
03-30-2009 04:06 PM
Dkahnjob
Fountain
12
11-12-2007 04:21 PM
cig1988
Drives and Lower Units
2
05-28-2007 05:08 AM
azlineman
3
01-18-2004 11:18 PM
