What is the Best way to wash a Cockpit cover?? >
Old 05-10-2003 | 04:54 PM
HiPerf2000's Avatar
Question What is the Best way to wash a Cockpit cover??
My cockpit cover is looking kind of dirty....and the boat in the rack on top of me leaked some oil down on my boat. So now i have an oil stain too. i brought the cover home and i'm wondering what the best way to wash it is. I think i took it to a self serve car wash before and pressure washed it, but i was wondering if i could just throw it in the washer at home??
How do you guys wash yours??
HiPerf2000 is offline
Old 05-10-2003 | 05:45 PM
Charter Member #415
Your wife will kill you when the washer wipes out,plus you will have to buy her a new one. Find a commercial laundermat,feed in a bunch of quarters then run fast before the owner sees what you did
Magicfloat is offline
Old 05-10-2003 | 05:47 PM
CAP071's Avatar
I mix up hot water and simple green strong solution with a brush for mine.
Or just use straight Mountin Dew mix!
CAP071 is offline
Old 05-10-2003 | 07:25 PM
Sammy
Try pre treating the oil spot with Lestoil and then take it to the launderamat. Use one of the big front loaders, good luck.
Sam
Old 05-10-2003 | 07:39 PM
Formula Dude
I've done the wash machine route, before. The problem I encountered was the thread came apart around the snaps and borders. Maybe I should have used the "gentle" cycle. I had to have the entire cover restictched and new snaps installed.
Old 05-10-2003 | 08:16 PM
Strip Poker 388's Avatar
Rob
when you wash it. be carefull the soap will take OUT the water repellent.woollite or verry mild detergent
Strip Poker 388 is offline
Old 05-10-2003 | 08:22 PM
boatfreak's Avatar
I used the car wash on my old boat cover and it did a good job.
boatfreak is offline
Old 05-10-2003 | 08:24 PM
CAP071's Avatar
I scrubed mine with hot water n simple green than rinsed it with a pressure washer came out great I let it dry than sprayed it with water repellant .
CAP071 is offline
Old 05-10-2003 | 08:27 PM
take it to a commercial laundry for a wash, but only spin dry slighty, leave it damp and dry it on your boat for a perfect fit...
burtandnancy is offline
Old 05-10-2003 | 08:41 PM
Official OSO boat whore
If you decide to add water repellant, remember that the stuff makes the cover shrink. The first time we couldn't even get the cover back on. The second time, I applied it with the cover in place. It proceeded to actually pull the aluminum frame off the window!
Cord is offline
