Double shakedown cruise
Old 05-11-2003 | 04:26 PM
mopower's Avatar
Toxic FORMULA
Default Double shakedown cruise
Well , I've been waiting for about two weeks for a decent day. Cloudy today with severe thunderstorms for this afternoon. Lets go now.
Truck towed like a RR locomotive
mopower is offline
Old 05-11-2003 | 04:34 PM
mopower's Avatar
Toxic FORMULA
Out on the water gave the 540's a short blast up to 4200 and 76 mph GPS. Still had throttle and trim left. Backed off and ran a couple of miles at 3000 and 50 mph.
mopower is offline
Old 05-11-2003 | 04:37 PM
mopower's Avatar
Toxic FORMULA
Made a wide u turn near the Ben Frankin Bridge and as I was banked , noticed a fluctuation in the left oil pressure that stopped when I returned to a level position . Sooooooo , stop to investigate . Open the hatch to this...
mopower is offline
Old 05-11-2003 | 04:39 PM
mopower's Avatar
Toxic FORMULA
Popped an oil line coming out of the cooler under the distributor returning to the block . Shut it down and made the 4 or 5 mile trip back on one engine. Thank God for twins Was smart enough to open breaker for bilge pump too.
This is a hellava way to change oil...
mopower is offline
Old 05-11-2003 | 04:42 PM
mopower's Avatar
Toxic FORMULA
Just got back from dinner. Now go get out the power washer and clean this thing before climbing in and working on it
mopower is offline
Old 05-11-2003 | 06:12 PM
mopower's Avatar
Toxic FORMULA
OK , its 7:15 and just got done with the Simple Green and power washer and things are looking a whole lot better. I can also get my hand on the lower end of the oil line where it goes into the block. Maybe I can do this with out removing the exhaust I hope
mopower is offline
Old 05-11-2003 | 07:59 PM
Roger 1's Avatar
WOW! If that don`t put the shake in your shakedown cruise I don`t know what will!
Glad you caught it in time.......................................you did catch it in time did`nt you.
Roger 1 is offline
Old 05-11-2003 | 08:31 PM
Waterfoul's Avatar
Gone Fishin'
So, did you catch it in time??
If so, how lucky are you that you noticed the gauge fluctuation when you turned. A LOT of people woulnd't.
Waterfoul is offline
Old 05-11-2003 | 09:06 PM
mopower's Avatar
Toxic FORMULA
Yeah , I think I'm safe. The pressure never dropped below 40 lbs from about 64lbs. As soon as I straightened out and the boat was level again it came up. I figured I may be low on oil. But I must have put at least two gallons all over the engine compartment. Here's the culprit , at least it wasn't a condom
The PINHOLE is between my finger nail and the crimp.
mopower is offline
Old 05-12-2003 | 11:32 AM
mopower's Avatar
Toxic FORMULA
One new hose and 7 qts of Pennzoil later we're ready to go again
mopower is offline
