Chevy Big Block Water Pump to bypass >
Old 05-11-2003 | 09:25 PM
Default Chevy Big Block Water Pump to bypass
What are the advantages and disadvantages of eliminating a stock water pump on a Chevy Big Block and installing bypass tubes and thermostat housings on twins? And would you suggest using thermostats or not?
horizontalboggi is offline
Old 05-12-2003 | 04:13 PM
I'd like to know this too
88 MACH 1 is offline
Old 05-12-2003 | 04:33 PM
convincor's Avatar
56 veiws and no replies???
I was thinking of this also.
Let's hear some input.
convincor is offline
Old 05-12-2003 | 04:35 PM
Just went through this. It is a pain. Do a search on Dump Valves and you will get an idea what you are in for. Unless you are running a blower I would leave well enough alone.
BadDog is offline
Old 05-12-2003 | 05:12 PM
CESSNA
What year and type motor s???I'veseen this done on a dyno and it added about 14 h.p. to the 500 h.p. and it was simple and a quick change to do ,he said it gave better water flow which sounds hard to beleive but he said it took the pump out of the way of the pressure water from the sea water pump and stoped air pockets ????
Old 05-12-2003 | 05:14 PM
Official OSO boat whore
Leave it alone. The stock circ pump adds just enough restriction to the system so that you won't have water pressure or temp problems.
Cord is offline
Excalibur Dude
5
07-17-2007 01:37 PM
Hydrolift
5
08-05-2006 12:04 PM
homan
9
08-24-2004 12:00 AM
convincor
7
04-17-2003 11:30 AM
THEJOKER
09-13-2002 02:41 PM
