Fountain water drain design question. >
Old 05-12-2003 | 09:34 AM
GNJ2
Question Fountain water drain design question.
Can any other fountain owners out there relate or help me with this? I have a 98 32' Fever. When water gets into the cockpit area, it appears to drain from the floor in two drain areas in front of the back seat. However, the water eventually ends up in the cabin carpeted floor area after a while. I know there is a bilage pump under the step going into the cabin that is designed to pump out the water, but it only comes on after the level gets high enough activate the float switch. It seems like a kooky drain design to me. Why didn't Fountain drain into the engne compartment where the two bilage pumps can expell it? Any comments?
Old 05-12-2003 | 09:49 AM
On a 35 I have there is a plug in the cabin to keep the bildge water out.
Dixie Doug is offline
Old 05-12-2003 | 10:00 AM
GNJ2
Default Fountain water drain
Where is the plug? If you can plug it, what happens to the water?
Old 05-12-2003 | 10:08 AM
In the floor sump .If you plug it the water can't go into the cabin.
Old 05-12-2003 | 10:17 AM
GNJ2
Doug: If you plug it, where does the water drain then?
Old 05-12-2003 | 05:00 PM
later's Avatar
My 42 water drains into engine compartment
later
later is offline
Old 05-12-2003 | 09:33 PM
yzbert's Avatar
check to see wear your ice chest drains as well, my 32 1994 would drain into a stringer and get stuck, would not have noticed it but i cracked my cooler and neaded to replace it, dropped the drain hose and when i was reaching for it found really gross water.
yzbert is offline
Old 05-12-2003 | 09:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I noticed the same thing on my '99.
I'm going to install a tee w/checkvalve in the sink drain. Piss poor design draining water into the hull if you ask me!
US1 Fountain is offline
Old 05-13-2003 | 09:40 AM
GNJ2
Default Fountain Water Drain
Thanks, I appreciate the input.
mccaffertee
06-20-2009 11:37 PM
Hot Stepper
10-20-2008 04:04 PM
bwiencek
2
04-28-2008 11:50 AM
Phastenuf
2
01-03-2008 09:09 PM
Blue by You
8
01-20-2007 10:17 AM
