Would You Buy a Boat with TRS drives? >
Old 05-13-2003 | 10:16 AM
Bam Bam's Avatar
Question Would You Buy a Boat with TRS drives?
I have been eyeing a beautiful Pantera boat that fits within my limited price range. However, it has TRS drives which makes me nervous due to the ability to get parts.
I just got rid of my last boat because of an outdated King Cobra drive.
So I need help, would you buy a boat that has TRS drives?
Bam Bam is offline
Old 05-13-2003 | 10:35 AM
Yes, I would and did, you can still buy most parts for TRS, just go to Doller Offshore, or BAM's website and look at the part listings, there are only a few parts that are no longer available. and unless you are putting tons of HP behind them, or badly neglecting them they are a very solid drive.
THRILLSEEKER is offline
Old 05-13-2003 | 10:44 AM
Sean's Avatar
TRS drives hold up very well and the parts are still available. There also alot of used parts\drives available too.
Sean is offline
Old 05-13-2003 | 10:49 AM
McGary911's Avatar
My Donzi has a TRS. Like they mentioned, parts are available if you know where to look. The MercII transmission may not be available, but all the wearable parts are available, from what i hear. Borg Warner makes a compatable transmission as well. TRS drives can handle a good amount of power, and the transmissions make them smoooooth shifters. Never gonna hear a grinding gear with this setup (unless you have bigger problems).
McGary911 is offline
Old 05-13-2003 | 10:57 AM
RUSSSR1's Avatar
What kind of HP will a TRS handle?
What is the weak link the drive or the trany?
RUSSSR1 is offline
Old 05-13-2003 | 01:24 PM
Personally, I would not buy a boat with TRS drives. It has nothing to with the reliablity. It has to do with the fact that nobody around here has the expertise to work on them or the parts to fix them.
If I trash a Bravo, I can find a new or used one at a reasonable price and be back on the water in few days. I've done it. Trashed a drive on Sun and on the water by Weds. With a TRS, it would probably be closer to a month.
Griff is offline
Old 05-13-2003 | 01:30 PM
GLH's Avatar
GLH
Default Would You Buy a Boat with TRS drives?
If the deal is right;
meaning cash left for a spare lower and tranny to cover time of rebuilts, when one goes t!ts up. And resale impact (I did say deal is right)
YES
GLH is offline
Old 05-13-2003 | 01:39 PM
BLee's Avatar
Charter Mod
Mack at Doller can get whatever you need for the TRS setup. The ole 92 had em. I blew 2 over 7 years. It was still smoother shifting than my new Gun!
BLee is offline
Old 05-13-2003 | 03:23 PM
DEVIL MAN
I would not put TRS drives with over 550 horses...just to be safe. If the boat is a steal, go with the TRS drives knowing someday you might have to convert to a Bravo. The TRS setup will be a tougher sell for you when you go to dump the boat. Most people don't know anything about a TRS drive or if they do, they do not want to mess with it. Like someone mentioned about the Bravo Drive...they are now a dime a dozen and it is a quick and easy fix.
As long as you know what you are getting into...you are ok. Looks like you are doing your homework. Good luck.
DMan
Ps. Had TRS drives on my 91 38 Fountain Fever with the 425HP's. They worked well and shifted great, but I blew them to hell and back when I put the 800 horsepower supercharged engines to them. Man....those things blow gooooood!!!! Turned me into a speedmaster III guy real quick!!!!
Old 05-13-2003 | 04:18 PM
buckknekkid's Avatar
Talking chalk up one for the geriatric crew
exshellent research
T.O.
buckknekkid is offline
