Hydrolic Steering Bracket? >
Old 05-13-2003 | 11:55 AM
Tantrum's Avatar
Default Hydrolic Steering Bracket?
Im installing an IMCO single ram bracket on my new drive. There is a piece that has a ball bearing and a spring. What kind of grease should I use on this. Obviously it is there to apply tension but I dont have it apart yet so Im not sure what it is riding up against.
On another post I was told to torque bolts between 18-22lbs. Should I use Lock Tite?
Any pionters or anything else I should know?
Tantrum is offline
Old 05-13-2003 | 01:16 PM
Scott72
I just installed my IMCO steering this weekend. I used the Mercruiser Teflon grease (it's in a tube - greenish in color) per a boat mechanic friend on the ball and spring. I only used the loctite on the two bolts that had to be drilled and taped in the upper outdrive case (nerve-racking process drilling the case - afraid I'd crack it). I didn't use loctite on the 3 stock bolts because it didn't look like there was any on there to begin with.
32Fever97
Drives and Lower Units
0
07-05-2007 02:33 PM
FIVEPTOHH
Fountain
1
11-16-2006 09:08 PM
thisistank
04-04-2006 08:12 AM
dukenrock
06-18-2005 11:25 PM
BAJA WILL
6
08-06-2003 11:10 AM
