msd box
Old 05-14-2003 | 08:55 PM
CONVINCOR 251
Lightbulb msd box
I was wondering if any one is or has tryed to run a msd 6al box on there boat and if you had any troubles ,I know I should put a marine one on it but I have a spare 6al.
Old 05-14-2003 | 10:49 PM
paradigm shift's Avatar
Yea I know it is not marine approved. I have ran one an open engine compartment for 3 yrs and now more 2 yrs in an enclosed. No trouble. Hope I did not jinx myself.
paradigm shift is offline
Old 05-15-2003 | 06:15 AM
Official OSO boat whore
Don't worry about the box. It's fully potted so there is no risk of sparking.
Cord is offline
Old 05-15-2003 | 06:49 AM
Ya. I have used a regular 6a as well. The only difference is color of the box and the connections. They have 3 rubber rings that act as gaskets for the connections.
DAVE
Dave F is offline
Old 05-15-2003 | 03:34 PM
bobby daniels
Thats all I use and they work great ,there is a nother big difference the rev limiter is external on the marine and the limiter
works faster so its not as noticable as the 6al (no big deal )
USE the 6AL and blaster 2 coil
Old 05-15-2003 | 04:09 PM
Pantera24's Avatar
I use MSD 6T's with soft touch rev controls and blaster coils. Work real good.
Pantera24 is offline
Old 05-16-2003 | 08:00 AM
Ratchet's Avatar
Everyone I know uses the 6 als...................
Ratchet is offline
Old 05-16-2003 | 03:11 PM
bobby daniels
6t's and 6al's are both good ,6 AL's are the most used I think
Old 05-16-2003 | 09:00 PM
CONVINCOR 251
Looks like 6al is a winner..
Thanks alot
Old 05-18-2003 | 09:33 PM
red racer
I was concerned, like you, about the 6AL...
I called MSD direct and they told me that while the unit was internally covered completely in resin, the connections inside are not. This will cause corrosion internally and eventually failure. Their suggestion was to seal the basic wire openings, yet leave the riveted side down for water drainage. Sealing it completely would hold the moisture inside causing more corrosion.
My concern, in the event of failure, is you can't see how bad the connection are getting and replace them before they fail... You will be stuck with our pants down.
My problem will be replacing it for $500+ (unit and rev limiter). Wait and be stuck or replace it when the budget will allow it????
Looking for advice also....
Red Racer
