stock merc. 502efi manifolds mods.? >
Old 05-15-2003 | 08:14 AM
26sonic's Avatar
Default stock merc. 502efi manifolds mods.?
what if any performance gains would you get by modifying the stock merc. manifold on a 502 efi? az speed and marine sells a "short runner " manifold which is a stock manifold with machining work done to it ? i already have the az speed and marine "super tune kit" (ecu re-prog. , adj fuel reg, k+n filter, msd ignit.) plan to add rev. marine exhaust and was wondering if this modified manifold would benefit. also was told the ecu would have to be re-programmed slightly by az speed and marine to compliment the change.
26sonic is offline
Old 05-15-2003 | 09:46 PM
rayseaeddie
unless you're redy to spend some money on heads,cam,and exhaust I seriously doubt you would be thrilled with the results. ASM is a great company with loads of experience. You need to dictate your goals. 1,2,3,4,5,6,7,8,9,10 mph?
Old 05-16-2003 | 06:49 AM
Raypanic's Avatar
Did you see this post?: http://www.offshoreonly.com/forums/s...ght=Boostpower
Ray
Raypanic is offline
266ltd
12
01-30-2008 02:28 PM
HiPerf2000
6
03-16-2007 08:59 PM
BURNSMAZZ
9
11-16-2004 07:42 PM
26sonic
2
04-01-2003 08:15 PM
Cattitude
8
05-19-2002 03:58 PM
