Help with oil reading of 496HO >
Old 05-15-2003 | 10:47 AM
rv
Default Help with oil reading of 496HO
Can anyone help explain why the oil level on the dip stick for the 496HO is about 3/8" different between one side of the stick and the other? This has me concerned about obtaining an accurate reading.
Thanks,
Rick
rv is offline
Old 05-15-2003 | 11:28 AM
CigDaze's Avatar
That's odd...I only have marks on one side.
CigDaze is offline
Old 05-15-2003 | 12:09 PM
rv
The stamped marking(shows 'add' and 'ok' levels) on the stick is only on one side. What I was referring to is the actual oil residue that is on the stick when you remove it for viewing the oil level. The residue left on the stick is different on one side vs the other side. It is almost like something is wiping some of the oil off of the back side of the stick.
rv is offline
Old 05-15-2003 | 12:19 PM
CigDaze's Avatar
Oh...I see now. It's probably because the stick is entering the pan on an angle. With surface tension, it probably isn't wetting the upper side of the stick as far as the lower side. Try shaking is a little while it's in the pan then pull it out. Sometimes twisting it a little helps. Mine is always even.
CigDaze is offline
Old 05-15-2003 | 03:12 PM
rv
Baja,
Thanks for your reply. I will give that a try.
Another others out there with this engine see this???
Rick
rv is offline
Old 05-15-2003 | 07:03 PM
AZDominator
No
Old 05-15-2003 | 07:36 PM
Yes,
Every BBC I have owned has two levels on the stick. One side says F and the other is between A and F. I just keep it at F on the backside and half way on the side that is marked. Shove it in the other way and it is reversed.
BadDog is offline
exmark31
3
06-29-2007 11:44 AM
BadDog
2
06-22-2007 08:03 AM
davis777
4
07-18-2006 08:09 AM
vandeano
32
10-22-2005 04:07 PM
Ck1flyer
5
07-18-2005 01:13 PM
